FAQ: 2005 - 2007 LX Fuse Identification - Chrysler 300C Forum: 300C & SRT8 Forums
Tech Tips - DIY - How-To Member created and Member approved! From modifications to maintenance, find the step-by-step info you need here. (Only Moderators can post)
post #1 of 2 (permalink) Old 09-18-2011, 06:43 PM Thread Starter
Points: 26,977, Level: 1 Points: 26,977, Level: 1 Points: 26,977, Level: 1
I've been reading a lot of posts as of late regarding electrical and people getting confused about fuses so here is a complete break down for the 2005-2007 300C's and other LX's
Before i go any further i have to say this to cover myself, When replacing a blown fuse, it is important to use only a fuse having the correct amperage rating. The use of a fuse with a rating other than indicated may result in a dangerous electrical system overload. If a properly rated fuse continues to blow, it indicates a problem in the circuit that must be corrected.
Cavity is fuse location which can be found on the underside of the fuse box lid.
FRONT FUSE BOX (under hood passenger front) also contains relay's
Cavity 1 - 20 Amp Yellow fuse - Fuse for Left Headlight High Beam
Cavity 2 - 20 Amp Yellow fuse - Fuse for Right Headlight High Beam
Cavity 3 - 15 Amp Dark Blue fuse - Fuse for Adjustable Pedals (some models don't have this)
Cavity 4 - 20 Amp Yellow fuse - Fuse for the Horn
Cavity 5 - 25 Amp Clear fuse - Fuse for headlamp washer (only on the 05-07 5.7 and 6.1 300C)
Cavity 6 - 15 Amp Dark Blue fuse - Fuse for FCM aka Front Control Module
Cavity 7 - 20 Amp Yellow fuse - Fuse for fog lamp
Cavity 8 - 15 Amp Dark Blue fuse - Fuse for parking lamp
Cavity 9 - 15 Amp Dark Blue fuse - Fuse for non ABS brakes
Cavity 10 - 5 Amp Orange fuse - Fuse for starter
Cavity 11 - 20 Amp Yellow fuse - Fuse for auto shut down/powertrain control module (PCM)
Cavity 12 - not used
Cavity 13 - not used
Cavity 14 - 25 Amp Clear fuse - Fuse for powertrain control module (PCM)
Cavity 15 - 20 Amp Yellow fuse - Fuse for fuel injectors, ignition coils
Cavity 16 - 15 Amp Dark Blue fuse - Fuse for powertrain control module (PCM)
Cavity 17 - 30 Amp Pink fuse - Fuse for ABS system valves
Cavity 18 - 30 Amp Pink fuse - Fuse for windshield washer/wiper
Cavity 19 - 50 Amp Red - Fuse for radiator fan
Cavity 20 - 20 Amp Light Blue fuse - fuse for starter
Cavity 21 - 50 Amp Red fuse - ABS pump motor
Cavity 22 - 40 Amp Green fuse - fuse radiator fan high/low
Cavity 23 - 50 Amp Red fuse - fuse for high intensity lighting
Cavity 24 - not used
Cavity 25 - 30 Amp Pink fuse - fuse for left high beam right low beam
Cavity 26 - 20 Amp Light Blue fuse - fuse for Transmission
Cavity 27 - 30 Amp Pink fuse - fuse for right high beam left low beam
REAR FUSE BOX
Located in the trunk under the spare tire access panel. This also contains fuses and relays
Cavity 1 - 60 Amp Clear fuse - Fuse for Ignition Off Draw
Cavity 2 - 40 Amp Green fuse - Fuse for the Battery
Cavity 3 - Not Used
Cavity 4 - 40 Amp Green fuse - Fuse for the Battery
Cavity 5 - 30 Amp Pink fuse - Fuse for Heated seat and Steering Column
Cavity 6 - 20 Amp Yellow fuse - Fuse for Fuel Pump
Cavity 7 - Not Used
Cavity 8 - 15 Amp Dark Blue fuse - Fuse for Ignition Start/Run - Start
Cavity 9 - 20 Amp Yellow fuse - Fuse for Console Power Outlet
Cavity 10 - 10 Amp Red fuse - Fuse for Rear Fog Lamp (If equipped)
Cavity 11 - 25 Amp C/BRKR fuse - Fuse for Memory Module/Door Locks
Cavity 12 - 25 Amp C/BRKR fuse - Fuse for Passenger Power Seat
Cavity 13 - 30 Amp C/BRKR fuse - Fuse for Door Module Run/ACC/Delay
Cavity 14 - 10 Amp Red fuse - Fuse for Sentry Key, Remote Key less Entry, Cluster
Cavity 15 - 20 Amp Yellow fuse - Fuse for Brake Light (5.7L)
Cavity 16 - 20 Amp Yellow fuse - Fuse for Trunk Power Outlet (If equipped)
Cavity 17 - Not Used
Cavity 18 - 20 Amp Yellow fuse - Fuse for Selectable power outlet
Cavity 19 - 10 Amp Red fuse - Fuse for Stop Lamp
Cavity 20 - 20 Amp Yellow fuse - Fuse for Rear Wiper (Magnum)
Cavity 21 to 26 Not Used
Cavity 27 - 10 Amp Red fuse - Fuse for Airbag/Occupant Classification Module
Cavity 28 - 10 Amp Red fuse - Fuse for Curtain Airbag - if equipped
Cavity 29 - 5 Amp Orange fuse - Sentry Key/Remote Keyless Entry/Powertrain
Control Module Ignition Feed
Cavity 30 - 10 Amp Red fuse - Fuse for Steering Column Module/Power Mirrors - if
equipped
Cavity 31 to 34 Not Used
Cavity 35 - 5 Amp Orange fuse - Fuse for Power Antenna/Garage Door Opener/Ignition Delay
Cavity 36 - 20 Amp Yellow fuse - Fuse for Radio/Navigation
Cavity 37 - 15 Amp Dark Blue fuse - Fuse for Transmission
Cavity 38 - 5 Amp Orange fuse - Fuse for Analog Clock/ Garage Door Opener
Cavity 39 - 10 Amp Red fuse - Fuse for Heated Mirror
Cavity 40 - 5 Amp Orange fuse - Fuse for Power Mirror
Cavity 41 - 10 Amp Red fuse - Fuse for Climate Control Module/Headlamp Leveling — if
equipped/Rear Park Assist — if equipped/Tire
Pressure Monitoring — if equipped
Cavity 42 - 30 Amp Pink fuse - Fuse for Automatic Temperature Control (ATC) Blower Motor
Cavity 43 - 30 Amp Pink fuse - Fuse for Rear Defroster
Cavity 44 - 20 Amp Light Blue fuse - Fuse for Audio Amplifier
There it is ladies and gents! hope this helps!
CoolVSRT8 is offline
post #2 of 2 (permalink) Old 09-28-2011, 12:22 AM
Elite Contributing Member
Points: 65,124, Level: 1 Points: 65,124, Level: 1 Points: 65,124, Level: 1
Bronek's Avatar
Send a message via MSN to Bronek
Add to Fuse 38, Compass control, as I found out the hard way.
Sabrina - Srebrny Księżna
2005 300 Limited AWD ~ FE210 AWD? Maybe...
Click below for current mods + future plans
I do not believe in fire-breathing dragons, multi-coloured unicorns, good-willed people, omni-present creators, or other mythical creatures.
Bronek is offline
  LinkBacks (?)
LinkBack to this Thread: http://www.300cforums.com/forums/tech-tips-diy-how/94033-faq-2005-2007-lx-fuse-identification.html
Posted By For Type Date
SOLVED: Hi, I have a 2005 Chrysler 300C and the seat - Fixya This thread Refback 01-11-2017 05:34 PM
Heated seats not working on 2005 300c [Solved] - Fixya This thread Refback 10-16-2016 11:46 AM
20 Most Recent 2005 Chrysler 300 Questions & Answers - Fixya This thread Refback 09-25-2016 03:03 PM
Chrysler 300C Forum: 300C & SRT8 Forums This thread Refback 01-18-2016 07:16 AM
EXPIRED: 2005-2007 nav Chargerdude70 Parts Buy/Sell Forum 0 11-27-2011 05:01 PM
EXPIRED: 2005-2007 air bag kit threehundredC Parts Buy/Sell Forum 22 06-10-2011 07:24 AM
2005 chrysler 300 fuse diagram scorpion Problems / Dealer Service 0 12-31-2010 06:07 PM
EXPIRED: WTT: my 2005 rec nav for your 2007 GROUNDED Parts Buy/Sell Forum 1 09-23-2008 02:36 PM
Fuse 11 on a 2007 EXTREME-SRT8 1st Gen SRT8-Specific General Discussion 4 03-03-2007 07:55 AM
