Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Tech Tips Forum > Tech Tips for Review
Old 10-16-2009, 11:50 AM   #101 (permalink)
Points: 818, Level: 1 Points: 818, Level: 1 Points: 818, Level: 1
Veehawk's Avatar
Car: 2006 Chrysler 300C Heritage Edition
Member Number: 22226
Originally Posted by Fisch View Post
I would still do it. And as Veehawk said, the top really isn't open when the hood is closed, as the hood presses against the top rubber of the filter housing. However, the hole in the bottom of the housing that your stock air box went down into is still going to be "restricted" by the air silencer. I'd still take it out and allow for more air to shoot up that hole into your AFE.
After removing my lower vent covers and the air silencer, I have been thinking about running some sort of tubing from the lower vent directly to the hole in the air box where the silencer used to attach - giving the air box a sort of "ram air" effect. I've heard some people have done this, but I've also heard that this could assist moisture getting into the box/filter as well - so I'm holding off for now until I research this idea a bit more.
No need for ramps - I took my fascia off and removed the air silencer with the wheels on the ground. It's not tough to remove the screws underneath as long as you are cool with laying on your back.
I'm stationed in the swamps of Georgia where it's currently raining. It rains here almost daily. Sadly, my new house doesn't have a garage so I'd be doing this on my wet driveway while crawling around with fire ants, snails, and these other strange bugs I've never seen before. I want a pair of ramps anyways just so I can crawl under the car and tinker with things much easier.
Daniel
2006 300C Heritage Edition
Inferno Red Crystal Pearl
186 T-stat w/ fan mod
DS Predator 93 CAI tune
AFE Stage II CAI
35% tint (not dark enough)
Exhaust work is soon to come
Catch Can is also soon to come
Intake Silencer delete coming soon
Veehawk is offline
Old 10-16-2009, 05:38 PM   #102 (permalink)
Points: 4,968, Level: 1 Points: 4,968, Level: 1 Points: 4,968, Level: 1
Activity: 40% Activity: 40% Activity: 40%
NWH_300C's Avatar
Car: 2006 Chrysler 300c Magnesium Pearl
Member Number: 15764
I took off my fascia as well to remove the silencer. Took 15 minutes. This way the bolt is easy to get to, you won't need an extension, and no ramps. Also with the fascia off its a good time to remove the drivers side lower baffle near the radiator to free up more airflow.
NWH_300C is online now
Old 10-16-2009, 06:38 PM   #103 (permalink)
Points: 741, Level: 1 Points: 741, Level: 1 Points: 741, Level: 1
Member Number: 23719
I took mine out when I had the fascia off as well. It was also the same day I was installing my ARIA and HID's
Big Daddy D 300C is offline
Old 10-18-2009, 09:01 PM   #104 (permalink)
Points: 1,224, Level: 1 Points: 1,224, Level: 1 Points: 1,224, Level: 1
SeaBass67's Avatar
Car: 2009 300C AWD
Member Number: 21324
No Hobby Shop at the Base?
Get a creeper with the ramps so you can stay away from the bugs!
SeaBass67 is offline
Old 10-19-2009, 10:28 AM   #105 (permalink)
Veehawk's Avatar
I'm used to doing everything myself at my old house in the garage. Standing in line for hours and/or waiting days to be put onto the waiting list just to get stall time while 9,000 other airman do the same just to do something simple on the car and having to pay for it = not too keen on that. I'll just go to a friends house that has a garage and knock some of this stuff out there.
Veehawk is offline
Old 10-23-2009, 08:47 PM   #106 (permalink)
SeaBass67's Avatar
Car: 2009 300C AWD
Guess I got spoiled at the small base I was at. You could drive in and basically rent a stall for however long you needed. Guys would replace motors on the spot!
Old 10-24-2009, 07:16 AM   #107 (permalink)
Veehawk's Avatar
I'm at the smallest base I've ever seen in my 12 years. It's so small that I thought it was just a mini museum outside of the actual base! It actually makes getting things done harder because there's still nearly 10,000 people competing for stall time at a rediculously small hobby shop.
I drive past it every day and see people in there doing simple things that they could do at home and tie up the place with cleaning their air filters or removing rust from their trailer hitches ffs. Meanwhile everyone goes downtown and just pays a shop to do things that they could and should get done on base. Then you have hundreds of retirees and civilians using up your assets onbase and you the active duty guy is at the end of the line behind all of them. That's what kills me the most. Try getting a hair cut on your lunch break and seeing a spouse with five kids in there next to half a dozen old war vets. I just go downtown to some chick salon that's empty and pay twice as much because it's more convenient. Yes, I'm slightly disgruntled atm...lol
Veehawk is offline
