Sorry to add to this again but one thing I forgot was to let those that dont know about the speed nut and body bolt helpful hint. I remember seeing this in another post and it is a awesome idea....Thanks to whoever it was that posted that info it was pure genius!
When you take off the 6 (3 on each side) push fastners in the front part of the fender wells just replace them with speed nuts. There is a notch on the facia that the speed nut just clips right in like it was made to fit, so now you can screw the inner fender well to the facia instead of using those plastic push fastners that break almost every time! Plus it saves you from buying the plastic fastners everytime you take the front end off. I used 1/4-20 speed nuts and body bolts and it worked like a charm.
Here is a speed nut:
Here is a body bolt:
Here is the original plastic push fastner that is in the fender well from chrysler:
