Trunk will not open - no power to release mech - Chrysler 300C Forum: 300C & SRT8 Forums
Technical Service Bulletins / Recalls This forum is for the discussion of TSB's (Technical Service Bulletins) and Recalls which involve the Chrysler 300 models.
post #1 of 15 (permalink) Old 02-08-2011, 12:49 PM Thread Starter
Points: 7,910, Level: 1 Points: 7,910, Level: 1 Points: 7,910, Level: 1
-=SpeedFreak=-'s Avatar
Car: 2005 Fully Loaded Hemi-C 300
Hey there folks am hoping someone can enlighten me on this issue I am having. I hit 100k miles and now my girl is showing her age ;-)
I have a 2005 300C. I was driving at night the other day and something looked different.
Come to find out the lighting on the fan speed, temp dials, and def/heat selecter were not lighting up. Nor was the analog clock.
Then I noticed that the interior lamps would not come on when entering the car, nor when turned on manually. And then the trunk won't open either with either the remote nor the button on the dash. there is not even a hint of a click happening which tells me there is no power going to it.
I reviewed the manual for the fuses but do not see any fuse that is common amongst the above.
I brought it to the dealer but after an hour they could not definitively determine what the cause is.
Anyone have any educated guesses?
-=SpeeedFreak=-
2005 300C Midnight Blue
E&G Grille / Chrome Pillars
255x45x20's on MC2-FZ16 Chrome Rims
Zoomers Cat Back Exhaust (removed 90Kmi)
Pedders Full Suspension
SuperChips Tuner Currently running 91 Tune
www.ihatedell.net
-=SpeedFreak=- is offline
post #2 of 15 (permalink) Old 02-08-2011, 12:59 PM
Elite Contributing Member
Points: 65,124, Level: 1 Points: 65,124, Level: 1 Points: 65,124, Level: 1
Bronek's Avatar
Send a message via MSN to Bronek
You got a fuse or a loose wire somewhere. I'm not familiar enough with the electronics, but the dealer not being able to diagnose it means you need to take your vehicle elsewhere.
Sabrina - Srebrny Księżna
2005 300 Limited AWD ~ FE210 AWD? Maybe...
Click below for current mods + future plans
I do not believe in fire-breathing dragons, multi-coloured unicorns, good-willed people, omni-present creators, or other mythical creatures.
Bronek is offline
post #3 of 15 (permalink) Old 02-08-2011, 07:44 PM
Points: 71,900, Level: 1 Points: 71,900, Level: 1 Points: 71,900, Level: 1
I did a search for you. Found this posted back in December:
"Success! Front Fuse #5 (25-amp) was blown. When replaced, my cabin lights, backlighting, and trunk opener magically work again! Hopefully it was a one-time fluke. I have extra 25-amp fuses now, just in case...
And for the record, I do have the HID w/ headlamp washers. Why these particular electrical functions are bundled together, I have no idea..."
Go get it!
DESIREE is offline
post #4 of 15 (permalink) Old 02-09-2011, 11:25 AM Thread Starter
ohhhh ohh I'm so excited. I will have to chek out this fuse.
If it is the fuse I am going to give the dealer HE double "L"
post #5 of 15 (permalink) Old 02-09-2011, 07:09 PM
This issue pops up on the forum every so often.
For other issues try using the 'search' feature. If something is happening to you odds are it's happened to others and they've posted it, and in most cases, gotten an answer.
Let us all know what you find in the fuse box.
Then stick the stealership's nose in the box and slam the lid!
DESIREE is offline
post #6 of 15 (permalink) Old 02-10-2011, 10:25 AM
Major Contributing Member
Points: 90,193, Level: 1 Points: 90,193, Level: 1 Points: 90,193, Level: 1
blacknight's Avatar
This maybe the culprit as I resolved teh same situation with a friends 04 Acura TL
Her memory seat, heated seat & windshield washer sprayers werent working,
Spoke to an Acura tech and he advised me to replace a specific fuse.
I replaced the fuse and the memory seat worked, the seat started to get warm and the wipers worked
But when I tried the use the washer sprayers....nothing happened and everything else above stopped working. I checked the fuse again and it blew.
Spoke with the tech and he said the pump for the sprayers is frozen along with the fluid in the resovoir.
I checked the resovoir and sure enough, it was frozen solid. granted it was about 2 degrees outside
I replaced teh fuse again and told her not to use the sprayers till it warms up.
A few days later it was in teh high 30's and we tried the sprayers and they worked fine.
So to the OP, I see you're in teh north east and we've had some blistering cold weather....That could be the problem
blacknight is offline
post #7 of 15 (permalink) Old 02-10-2011, 01:22 PM Thread Starter
desiree;
That was the culprit. I replace the #5 fuse and everything work. Thats for the help.
PS I did do a search on this b4 I wrote the query and found 5 hits. None of which had the solution.
Also when I was typing in the query, the forum found "related threads" which were the same ones I found as well.
In any case Problem solved :-)
post #8 of 15 (permalink) Old 03-16-2012, 05:31 AM
Points: 1,573, Level: 1 Points: 1,573, Level: 1 Points: 1,573, Level: 1
HemiLuv's Avatar
LOL, I feel ya on that
HemiLuv is offline
post #9 of 15 (permalink) Old 03-16-2012, 08:25 AM
[QUOTE=-=SpeedFreak=-;1010901]desiree;
That was the culprit. ]/QUOTE]
SCORE!
DESIREE is offline
post #10 of 15 (permalink) Old 03-16-2012, 12:17 PM
Points: 118,785, Level: 1 Points: 118,785, Level: 1 Points: 118,785, Level: 1
BobF's Avatar
Car: 2017 Chrysler 300S Ceramic Gray Clear Coat
Deleted
2017 Chrysler 300S
BobF is offline
trunk release problem simtso Problems / Dealer Service 5 06-20-2014 07:37 AM
Help!! Power seat release BigJ Problems / Dealer Service 4 01-23-2010 07:43 PM
Anyone ever actually LOOK at that little trunk release? OoTLink General Discussion 26 06-12-2006 10:01 PM
Trunk Release Hydraulic? y2kcurt General Discussion 3 04-06-2006 07:33 AM
Remote trunk release Jesus Chrysler Problems / Dealer Service 7 02-10-2006 12:44 PM
