Transmission Fluid Check - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Performance Forums > Power Train > V6 Engines > Transmissions, DriveShafts, Rear Ends
Old 03-23-2011, 09:00 AM   #1 (permalink)
Points: 1,039, Level: 1 Points: 1,039, Level: 1 Points: 1,039, Level: 1
Member Number: 31610
Send a message via Skype™ to jfblas
Where the heck is the transmission fluid dipstick located on a 300C?
jfblas is offline
Old 03-23-2011, 09:09 AM   #2 (permalink)
Administrator
Points: 287,160, Level: 1 Points: 287,160, Level: 1 Points: 287,160, Level: 1
Activity: 23% Activity: 23% Activity: 23%
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
There is no dipstick for our transmissions. You'll either need to get it checked at the dealer or buy a a Miller Tool #9336A used in conjunction with the chart below based on temperature. Here's one place you can get it -Miller Special Tools.
This is the chart...
Bernie
Rambit is offline
Old 03-23-2011, 12:55 PM   #3 (permalink)
Major Contributing Member
Points: 4,358, Level: 1 Points: 4,358, Level: 1 Points: 4,358, Level: 1
Car: 2010 chrysler 300c Bright Silver
Member Number: 9616
thanks for the fill graph.
jetech00001 is offline
Old 03-23-2011, 01:57 PM   #4 (permalink)
Points: 9,409, Level: 1 Points: 9,409, Level: 1 Points: 9,409, Level: 1
Car: 2006 Dodge Charger SRT8
Member Number: 18726
The only problem w/ that graph is you need to know the trans temp to be accurate..
1fst4dr is offline
Old 03-23-2011, 05:25 PM   #5 (permalink)
Member Number: 9616
would the trans temp be the same as the normal engine temp after it warms up as its cooled by the radiator just my thoughts .
Old 03-23-2011, 07:34 PM   #6 (permalink)
Points: 1,281, Level: 1 Points: 1,281, Level: 1 Points: 1,281, Level: 1
swalker's Avatar
Car: 2009 Chrysler 300C Heritage
Member Number: 25607
I use an infered thermometer and take the temp off the trans pan.
swalker is online now
Old 03-23-2011, 09:11 PM   #7 (permalink)
Member Number: 9616
thanks for the info makes sense getting reading from trans pan.
Old 08-01-2011, 06:00 PM   #8 (permalink)
Points: 1,113, Level: 1 Points: 1,113, Level: 1 Points: 1,113, Level: 1
Dualtriamp's Avatar
Car: 2007 Chrysler 300 SRT8
Member Number: 16753
Send a message via ICQ to Dualtriamp Send a message via AIM to Dualtriamp Send a message via MSN to Dualtriamp Send a message via Yahoo to Dualtriamp
I have an '07 300 SRT8 w/65K on it. Before the warrenty ran out I took it to the dealer because every once in a while I would be driving down the road, and I would step on the gas and nothing, it would rev a little but no pick up at all. If I shifted to neutral and back to drive it was fine. They told me there was an issue with the transmission leaking and they fixed it. The problem resurfaced and now it is out of warranty and they want $100+ just to look at it. So I looked through the forums and found the zip tie and graph sections (very helpful). Rather than a zip tie I just grabbed a long dipstick from a previous vehicle, cleaned it off and stuck it in till it bottomed out and removed it and there are 3.75 inches of fluid depth from the bottom of the dipstick to the fluid level. When I looked at the graph that translated to 95mm which is off the chart regardless of the temp. Am I doing this wrong or did the dealer overfill it. If they overfilled it what damage may have been done in the last 30K miles?
Dualtriamp is offline
Old 08-02-2011, 12:23 AM   #9 (permalink)
Member Number: 9616
i would think that the dip stick would be vehicle transmission specific .
http://millerspecialtools.spx.com/Detail.aspx?id=847
Old 08-02-2011, 06:43 AM   #10 (permalink)
Dualtriamp's Avatar
SPX Miller Special Tools | Detail: 9336A - DIPSTICK
According to the instructions that came with the charts:
Warm up the transmission, wait at least 2 minutes and check the oil level with the engine running. Push the Oil Dipstick 9336 into transmission fill tube until the dipstick tip contacts the oil pan and pull out again, read off oil level, repeat if necessary.
NOTE: The dipstick will protrude from the fill tube when installed.
The level is measured from the bottom of the dipstick not the top.
Other people hat have bought the tool say that the measurements start from the bottom at 0mm and there are marks every 10mm up to 100mm.
Mercedes CRD Auto Transmission Fluid Levels Check? RoughNeck6Zero European & Diesel Powered 300 Models 11 08-25-2009 11:26 AM
Transmission fluid capacity albow SRT8-Specific General Discussion 6 07-16-2007 05:08 PM
should i change transmission fluid? Jimmy General Discussion 1 10-17-2006 12:25 AM
Transmission Fluid COLOR? Jasper Problems / Dealer Service 12 12-21-2005 09:18 PM
Transmission Fluid Leak? jimhild General Discussion 10 12-01-2005 01:59 PM
