Old 04-03-2005, 11:38 PM   #11 (permalink)
joey
Member Number: 232
Thanks for posting the TSB.
I don't want to hijack this thread and turn it into a right pull/lead thread, but I will post my observations because the problem is still effecting many people.
I had my right lead/pull corrected back in December with a simple alignment.
Below were my ACTUAL caster settings after the alignment.
Compared to the original/first TSB my ACTUAL front left caster was out of spec.
Compared to the new TSB my ACTUAL caster are now in-spec, except for the cross caster.
What is important to note, however, is that even though my original/BEFORE was within spec with the new (and old) TSB, my car still pulled/lead to the right. My dealer didn't just stop there and return the car with the all too familiar "car is within spec" answer. Instead he worked/tweaked the caster/camber until he fixed the right lead/pull.
This is the difference between a good dealer and a bad dealer.
-----Caster Front Left------------Original 2004 TSB-------------------New 2005 TSB---------
Actual__Before_________Preferred Recommended Range______Preferred Recommended Range
__8.8____9.9_____________10.3______9.0 to 12.10____________9.4____8.40 to 10.40
----Caster Front Right---------
Actual__Before
__11.1__10.5_____________11.10_____9.0 to 12.10___________10.40___9.40 to 11.40
---Cross Caster Front-----------
Actual__Before
_-2.4__-0.6______________-0.80______-1.3 to -0.50__________-1.0____-1.60 to -0.40
joey is offline
Old 04-04-2005, 01:24 AM   #12 (permalink)
HEMEEE
Administrator
HEMEEE's Avatar
Car: '07 Chrysler 300C SRT8
Member Number: 664
This is great ResumeSpeed, thank you so much, from one of those still trying to resolve the right pull and soon to visit the dealership again Hope is a good thing
Linda... * More Pics *
HEMEEE is offline
Old 04-05-2005, 08:39 PM   #13 (permalink)
shaggy
Member Number: 176
What is the tsb for 5764376154 Uconnect inoperatable
What is the tsb for the the unconnect. Mine was factory installed and just stoped working check all connections may have a dead module.
Please post if you have access to this info
shaggy is offline
Old 04-06-2005, 02:59 AM   #14 (permalink)
ResumeSpeed
TSB/Recall Forum Moderator
ResumeSpeed's Avatar
Car: 2008 Fast, really really fast. Jeep!!
Member Number: 1725
Originally Posted by shaggy
What is the tsb for the the unconnect. Mine was factory installed and just stopped working check all connections may have a dead module. Please post if you have access to this info
The TSB does not give much diagnostics info. Check your module for the P/N range listed below. If you need the diagnostics procedures shoot me a PM, it's about 30pgs worth.
SUBJECT: UConnect Hands Free Phone Inoperative
NOTE: This bulletin applies to vehicles equipped with UConnect™ Hands Free Communications (sales code RSP) as listed below:
Module P/N 05064013AR or higher
DISCUSSION: If the UConnect Hands Free Phone is inoperative and if there are no DTC's, perform the existing diagnostic procedure available in TechCONNECT under: Diagnostics, Telecommunication, Voice Recognition/Phone Switch Circuit Short to Voltage. The problem may be an open phone button circuit. The diagnosis for the open phone button circuit is covered in the “Short To Voltage” test. There is no DTC for the open phone button condition.
ResumeSpeed is offline
Old 04-14-2005, 07:18 AM   #15 (permalink)
ChromeTailfins
Car: 1958 Plymouth Belvedere
Member Number: 633
I just had TSB#23-007-05a .. Rear Shelf Speaker Buzz/Rattle Sound performed.
Worked like a charm!
'58 Belvedere, '61 LeSabre, '96 Fleetwood, '07 SRX
ChromeTailfins is offline
Old 04-19-2005, 11:01 PM   #16 (permalink)
LoanWizard
Car: 2005 Black 300C
Member Number: 669
ResumeSpeed much thanks for list. I do hope that the administrator makes your list a Stickey.
Black 300C everything except all wheel drive.
LoanWizard is offline
Old 04-20-2005, 04:01 AM   #17 (permalink)
ResumeSpeed
Member Number: 1725
Originally Posted by LoanWizard
...I do hope that the administrator makes your list a Stickey.
If so I'll keep it up to date as often as possible, which I have already been doing.
Old 04-20-2005, 04:23 AM   #18 (permalink)
MrHappy
MrHappy's Avatar
Car: 2007 Chrysler 300 SRT8
Member Number: 1065
Gonna make my dealer's life too easy on em! Have a list of 8 things to fix, and 4 have a TSB with one other being the rims pitting issue. Does anyone know if there is a specific TSB for the issue some people mentioned where the climate control just stops pumping out warm air about a half hr unless you crank it all the way to heat? (And possibly related, the outside temp gauge will occassionally just jump 5 degrees above normal). I believe I saw it was a software flash, but didn't see an actual TSB for it.
MrHappy is offline
Old 04-20-2005, 09:04 AM   #19 (permalink)
jeepgrady
jeepgrady's Avatar
Car: 2005 C 300
Member Number: 415
I don't know about the heat sometimes not working properly, however, TSB # 24-004-05 relates to the a/c system cutting out at times. It may be related as the fix is new software. The TSB is for all 2.7 and 3.5 engines built prior to 8/19/04, and all Hemi's built prior to 1/31/05.
I am taking my "C" in tomorrow to have it updated.
jeepgrady is offline
Old 05-04-2005, 10:57 PM   #20 (permalink)
Hemi Dawg
Hemi Dawg's Avatar
Member Number: 589
crown sensitivity
I hate my 300c's crown sensitivity -- going to sell it and kiss chrysler good-bye for life
there is no tsb for it and right lead tsb says 'may or may not fix crown sensitivity'
so there is no fix?
- hemi dawg
Support our brave soldiers, sailors, airmen, and marines!
Hemi Dawg is offline
