The other day I pulled into a friends shop, its a old jiffy lube, It great cuz I can pull into there and go under ground and work on my car.
When I got under there there was alot of drips of water I assume a/c condensation all over my trannie and dripping off, This cant be a good thing?, Anyone else experience this itsa a 06 300c also there seems to be a lot of humidity in the car itself, like to the point were I turn on the defrost to clear the windshield.
Thanks
Trojan
You may be interested in this thread regarding water in tranny issues with '05 models, not sure how this affects '06 but it's worth the read: Transmission Problem with my C??
Includes all bulletins released through: Nov 10, 2005
Includes all LX Models: 300 series, 300C, 300N, 300M, Magnum, Charger and all RT and SRT-8 Models
1. TSB's (Technical Service Bulletins)...
--Compiled and maintanied by ResumeSpeed (c)2005
Just wanted to take the opportunity to express my thanks to ResumeSpeed for his diligent service to us all by keeping this invaluable resource current, and to give the thread a bump for our newer members' benefit.
Thanks, RS!!
PPP Meister Warrior cam-#01
GSM 1000 hp halfshafts-#01
SRT8 instrumentation-#01
Goodyear F1 GS-D3s-#01
Shock tower braces-#01
MotoRad 176° tstat-#01
DR Stage 2 heads-#02
SRT8 Brembos-#01
GSM 5.7L Mod-#01
Fast56K-TCM-#01
AirHammer-#01
12.97@107.7-#01
176 mph-#01
Willow: 1:44-#01
Laguna: 1:45-#01
12.3/113.8/1.74
I am about to take my car in for these suspected issues. The problem I am seeing is that none of these are supposedly happening on the 2006 300C which I have. Now, when scheduling my appointment should I just mention the problems or mention the problems and include the TSB's?
Canceled order and found a fully loaded '06 Cool Vanilla on the lot
Skyline: bpu's SOLD
Acura gsr-t: fully built sleeper style SOLD
Ford Focus: stock
64 1/2 Mustang: stock, maybe a 302 in the future
Ford F-150: work truck
Even though the TSB's would not necessarily apply, I would probably go ahead and mention them especially if the issue is exactly the same as what the TSB describes.
First off: Thank you for compiling and maintaining this list! It is an extremely valuable resource for us, the vehicle owners.
ANot too long ago I found a post related to noises from the sunroof. It gives instructions about inspecting the glass adjusting fasteners and if all else fails, drop the headliner and R&R all sunroof mounting bolts using Loctite. There is no TSB# associated with this (as far as I can see) and I don't see it anywhere on the list. Do you know where this info came from? My sunroof is noisy. I usually just crank the tunes, but it would be nice to get it fixed correctly.
Thanks Again for All of Your Efforts,
Dan
It Wasn't Me
(well, maybe once it was)
Is there any way to know if a TSB has been revoked by DCX. I'm being told that the TSB #05-005-05 …. Front And/Or Rear Brakes Squeal When Braking .. (SRT), is no longer being used and dealers are being told (one that I know of on the west coast and one on the east coast) not to replace the pads because this will not resolve the issue? Has anyone else heard this? The squeal my car is making seems to be getting worse by the day, if nothing else I will have to replace the pads and rotors my self.
__________________ 06' 300C SRT8 B.O. Date 9/29/05 Br Black
