Old 07-26-2007, 05:14 PM   #61 (permalink)
wild bill
Car: 2005 chrysler 300c
Member Number: 11
rear facia
how do you get the mat loose i removed the 2 pins. seems like it is stuck real tight, afraid to pull on it hard, i also removed the tail light nut.
wild bill is offline
Old 07-26-2007, 08:38 PM   #62 (permalink)
dfalconer
dfalconer's Avatar
Member Number: 12636
rear facia
Wild Bill,
- remove back carpet under trunk latch first (4 plastic inserts)
- pull out entire floor piece (no fasteners)
- remove 1 plastic insert and the taillight nut from side piece. Then pull out over the taillight bolt and rotate toward the center of the trunk - I did not completely remove. I don't think you can hurt them much. Lower corner at the back seat may bind a little may be easier if seats are folded first.
Don
dfalconer is offline
Old 07-27-2007, 04:55 PM   #63 (permalink)
wild bill
Member Number: 11
thanks for the reply, i will try that.
