Old 12-03-2006, 10:47 PM   #1 (permalink)
Black "C"
Member Number: 6836
Sunroof rattle....
I've experienced something like plastic rattling on the drivers side of the sunroof.
The dealer ofcourse says they can't find anything.
Anyone have this issue?
The sunroof is closed. When its opened it doesn't do it...
Thanks
Black "C" is offline
Old 12-04-2006, 06:55 AM   #2 (permalink)
pkh
Car: 2006 Chrysler 300C Hemi
Member Number: 5695
My sunroof seems fine when full on or off. But rattle when in push up position. Is that normal?
pkh is offline
Old 12-04-2006, 07:00 AM   #3 (permalink)
srt8danno
srt8danno's Avatar
Car: 2006 Chrysler 300CSRT8
Member Number: 1971
Here is a post I did a while back with links to sun roof rattles. Hope it helps.
Sunroof Rattle
2006 CSRT8- Silver Steel- everything but rear DVD/ tint 20%/Clear Bra of Death
March 29th, 2005 Ordered
February 10th, 2006 Built
February 21st, 2006 Delivered
THE LAST CUSTOM ORDERED SRT8 DELIVERED
330 days, 12 hours and 15 minutes to wait......and its all over but the DRIVING!!!
srt8danno is offline
Old 12-04-2006, 06:40 PM   #4 (permalink)
Spectre
Spectre's Avatar
Car: 2006 Chrysler 300C 5.7 Hemi with Sunroof
Member Number: 8007
Send a message via MSN to Spectre
mine sunroof squeeks when it's closed, think it's just the rubber rubbing against each other, is there anyway to fix it?
Spectre is offline
Old 12-04-2006, 08:31 PM   #5 (permalink)
FirstChrysler
FirstChrysler's Avatar
Member Number: 4664
The dealer of course says they can't find anything.
There is a TSB for this. It involved dropping the headliner, tightening the bolts holding down the moonroof, and putting some glue on it. Covered under warranty. It took a couple of hours to fix this for me. Sunroof no longer rattles, but the tech leaning on my seat back during the repair damaged my seat s that it creaks when you sit in it!
Originally Posted by Spectre View Post
mine sunroof squeaks when it's closed, think it's just the rubber rubbing against each other, is there anyway to fix it?
After fixing the rattle, I now can hear the squeak. I haven't had time to fix it, but it I understand that it is the glass rubbing against the seal. Lubricate the seal and the squeak will go away.
You'd think after all these years they would know how to make a moonroof!
FirstChrysler is offline
Old 12-04-2006, 09:18 PM   #6 (permalink)
Spectre
Spectre's Avatar
Member Number: 8007
so should i bring it back to the dealer to lube it? i did it and it came back after 3 days
Spectre is offline
Old 12-05-2006, 04:41 AM   #7 (permalink)
pkh
Member Number: 5695
Where exactly should I lube it? I don't think I have any rattle problem until I start using it because of the Summer.
pkh is offline
Old 02-13-2007, 11:04 PM   #8 (permalink)
mrcondor75
Member Number: 8331
Thanks
I had the same issue, dealer said there was a bulletin and fixed it, or so it seemed, it has improved to a quieter, more general rattle, but it is still there, I am going to take it back.
mrcondor75 is offline
Old 02-13-2007, 11:36 PM   #9 (permalink)
RYAN6969
Car: 2005 MIDNIGHT BLUE RWD 300C
Member Number: 4740
The product is called silicone emulsion. It is used to condition the rubber. I use it on all the family cars. I buy it from GM dealership. It is around $5cdn.
hope that helps.
RYAN6969 is offline
Old 02-14-2007, 05:27 AM   #10 (permalink)
joey
Member Number: 232
To lubricate the sunroof rubber seal, use silicon spray in a can that has a little red straw. You will need the straw to spray the backside/rear of the seal.
joey is online now
