it would work , remove the fuse & run a wire from the fuse feed side by putting a spade terminal in the hole & connect to pin 86 of the relay , pin 85 to earth ,pin 87 back to the other side of the removed fuse ( with an inline fuse holder fitted with the removed fuse) , pin 30 to a permanent or ignition live (with an inline fuse ) , job done
Slight change to above but YES it works , Remove fuse 11 & run the wire from the live side to number 30 on the relay , 87 on relay back to the other side of where the fuse was , 85 to earth , 86 has to be a switched live feed that is live while cranking , The cigar lighter circuit isnt so I wired in a switch from the live feed at the fuse box . Turn the switch off & the car wont crank (extra anti theft item) , flick the switch & start the car as normal. Job Done
2006 silver SRT8 sold
2007 silver SRT8 sold
Mercedes E55K AMG sold
Mercedes CL600 Bi Turbo V12 Sold
Didn't have time to probe around , all the places I tried
went 0 volts when cranking. There has to be a slight delay between putting power to pin 86
& cranking .
I dont understand why the self switching relay doesnt work. I'm more confused that you fitted one AND a switch. Dont knock it with your knee on the move! I think I'd want it well hidden away in case I brushed against it
on the positive side, it looks very oem - congrats
I'm confused because the wiring diagram in the OP shows that a switch isnt neccessary...you're duplicating a fully automatic relay with a button. You could have done the same thing, without ever needing a relay
