Permanently reset Fuse 11, this should do the trick ? - Page 3 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Performance Forums > Electronics For Performance > Tuning/CMR/Dyno/DataLogging/Gauges
Tuning/CMR/Dyno/DataLogging/Gauges This section is for all discussions related to hand held tuners, CMR tuning, Dyno Tuning, Data Logging & Gauges.
Old 02-11-2011, 05:16 PM   #21 (permalink)
Major Contributing Member
Points: 18,005, Level: 1 Points: 18,005, Level: 1 Points: 18,005, Level: 1
4herb2tas0tik's Avatar
Member Number: 846
I dont understand why you would want to do this? Is it going to make my car faster?
2005 loaded black "C">>which was bought back by dc<<
2006 loaded black srt8
mopar-cai..magnaflow catback..diablo sport tuner
180*t-stat..tinted led tails..5% limo tint all around..
color matched side markers@sirius ant..
2-jl 10w7's boston pro 6.5's
audio control lc8....orion hcca 250-g5
orion xterime 800.4 1600 watts total
>>custom install by wesexcellence<<
4herb2tas0tik is offline
Old 02-11-2011, 05:18 PM   #22 (permalink)
Points: 17,948, Level: 1 Points: 17,948, Level: 1 Points: 17,948, Level: 1
Car: . Mercedes CLS500{P1}
Member Number: 27889
You are exactly right , you don't need the switch if we can find an ignition 12volt supply that doesn't go to 0 volts when cranking , as you said you can forget the relay & just fit the switch if you like , I just ran out of time & it was raining so it was a quick fix .
2006 silver SRT8 sold
2007 silver SRT8 sold
Mercedes E55K AMG sold
Mercedes CL600 Bi Turbo V12 Sold
PHASEONE is offline
Old 02-11-2011, 05:25 PM   #23 (permalink)
Member Number: 846
I was just thinking.. Ive had my ride since 06 and ive never pulled fuse11.. I run my car like I stole it and I can tell you I love how my CP does great things like when iam going down the hwy at lets say 80 or so and if I start breaking my transmission switches into a lower gear..Kinda like its anticipating me hitting the gas.. what will this mod do?
Old 02-11-2011, 05:26 PM   #24 (permalink)
Points: 42,548, Level: 1 Points: 42,548, Level: 1 Points: 42,548, Level: 1
Activity: 80% Activity: 80% Activity: 80%
Kaiser Bill's Avatar
Car: 2008 300c SRT-8 {LCC}
Member Number: 21130
yes, much faster. Apparently, it works even better than resetting the adaptives with a Predator
this mod saves pulling out fuse 11 manually under the hood
The relay method automatically switches off the fuse whilst parked. The manual switch lets you do it whenever you want
http://www.300cforums.com/forums/gen...fuse-11-a.html
Watching You Avoiding Me!
Kaiser Bill is offline
Old 02-11-2011, 05:30 PM   #25 (permalink)
Member Number: 846
The relay method automatically switches off the fuse whilst parked. Thje manual switch lets you do it whenever you want
Ty nice read...but dam I would hate to loose how it drives now and it be worse..
Old 02-11-2011, 05:37 PM   #26 (permalink)
thing is Herb, the thing is adaptive....it learns the driver & traffic conditions....if you pull the fuse & then immediately drive like youre on fire, thats what it learns. Gradually it adapts cos generally we get stuck in traffic, or speed limits, so over a week or so it drops back into 'granny' mode
heres the benefit......pull the fuse & immediately drive like an axeman is chasing you. If it performs better than it does now, youre in clover. If it doesnt, it wont matter, because it will relearn how you drive now, & in a couple of weeks it'll return to what youve got at the moment, no harm done. Thats why we pull the fuse so often, because gradually the car returns to bumbling round
Old 02-11-2011, 05:48 PM   #27 (permalink)
Member Number: 846
I was just talking to a friend about this and he says that it has something to do with knock retard and that the motor will have more knock until the ecu changes it and he said thats where you gain and loose power?..Thanks for taking the time to explain this to me!
Old 02-11-2011, 06:03 PM   #28 (permalink)
thats doesnt sound quite right I'm afraid...I dont think it has anything to do with knock, unless thats a fuel adaptive catered for in the pcm.... mostly its the tranny
Originally Posted by 2006 300C View Post
Fuse 11 is the PCM (power control module) resets the adaptive settings that learn how you drive.
I gave mine a pull yesterday, and now with ESP ON it still spins on take off and pulls hard till I let off at 120 km/h I find for a luxury car its damn impressive!
Originally Posted by Murphy The Cat View Post
This is an old thread and pulling Fuse 11 only works on Oldies --- 2007 & earlier cars. On letter models, you've got other fuses to pull !
Prompted by a mention of 'Fuse 11' by Uk Chrysler 300C, I did a bit of digging around the forum to see what the fuss is all about (apologies to anyone who has seen posts about it in other sections of the forum).
Basically, pulling Fuse 11 from the fuse box for about 15 seconds and replacing it, resets the adaptive gearbox from lazyboy/granny mode to looney tunes mode (aka default, aggressive setting).
If you lift the fusebox cover from under the bonnet, locate Fuse 11 from the fusebox lid (its a yellow 20amp jobbie), do the business and away you go.
As a further accomponyment, some people also recommend recalibrating the happy pedal at the same time. To do this, turn the ignition on (but don't start the car), wait for the idiot lights to go out, slowly depress the happy pedal into the carpet, slowly lift the pedal up again, turn off the ignition, then start the car normally.
A quick word or warning !!!!!!!!!!
If the road is slightly damp and you have the Traction Control turned off, its VERY easy to get the big fella sideways.
For a few other threads on Fuse 11 and what it does, try here and here and here.
Old 02-11-2011, 10:54 PM   #29 (permalink)
Points: 2,322, Level: 1 Points: 2,322, Level: 1 Points: 2,322, Level: 1
yves's Avatar
Car: 2006 dodge magnum srt 8 and ram srt-10 QC
Member Number: 25016
Bill,
Phasone is correct about switch / 12 V AND relay, you can not put 20 amps on a simple switch, you risk to get a fire in the switch (and car)
Also, very clean installation with the relay ,as fuse 11 is integrated in it.
WANTED BADLY : DEAD or/and ALIVE ! LOL :
a wire with 0 volt at key off/key out and 12 volts at acc/ignition/cranking !
yves is offline
Old 02-11-2011, 11:08 PM   #30 (permalink)
No, I appreciate that you should use normally use a relay in any switched circuit, what I was trying to illustrate was that this particular relay design could have been autonomous, without a switch being needed at all - no holes in the dashboard, no risk of hitting the switch in motion etc
How-To: Stop dash rattles and squeaks permanently. dunsantos Tech Tips - DIY - How-To 9 07-28-2009 09:25 AM
Neat trick... saleen8927 General Discussion 11 03-31-2009 04:45 AM
Pull Fuse 11 PERMANENTLY? BuddyLee Performance General Discussion 6 10-21-2007 08:31 PM
Weird Chime after Fuse 11 reset???? FLAFIRE Problems / Dealer Service 2 06-19-2007 02:46 PM
Front Fuse Box --- 60 Amp Fuse SilverSea Problems / Dealer Service 7 12-09-2004 02:58 PM
