Permanently reset Fuse 11, this should do the trick ? - Page 4 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Performance Forums > Electronics For Performance > Tuning/CMR/Dyno/DataLogging/Gauges
Tuning/CMR/Dyno/DataLogging/Gauges This section is for all discussions related to hand held tuners, CMR tuning, Dyno Tuning, Data Logging & Gauges.
Old 02-11-2011, 11:14 PM   #31 (permalink)
Points: 1,281, Level: 1 Points: 1,281, Level: 1 Points: 1,281, Level: 1
swalker's Avatar
Car: 2009 Chrysler 300C Heritage
Member Number: 25607
I wish there was a way to fool the MDS system into not activating before 50MPH.
swalker is offline
Old 02-12-2011, 02:33 AM   #32 (permalink)
Points: 17,948, Level: 1 Points: 17,948, Level: 1 Points: 17,948, Level: 1
Car: . Mercedes CLS500{P1}
Member Number: 27889
Somewhere I have some capacitors , I just need to work out what value,s I need to hold up the 12volts while cranking & see if that sorts it
2006 silver SRT8 sold
2007 silver SRT8 sold
Mercedes E55K AMG sold
Mercedes CL600 Bi Turbo V12 Sold
PHASEONE is offline
Old 02-12-2011, 07:30 AM   #33 (permalink)
Points: 2,322, Level: 1 Points: 2,322, Level: 1 Points: 2,322, Level: 1
yves's Avatar
Car: 2006 dodge magnum srt 8 and ram srt-10 QC
Member Number: 25016
ok, i found one,
the pink/white wire at the back of the contact switch(key) positioned in the middle of the connector on the back is giving 12 volts at ignition AND cranking, this should do it,
according to the wiring diagrams,
that wire goes from ignition to a connector in the trunk PDC, changes color to pink/grey, and returns/arrives at the bottom of the underhood PDC (fusebox) in connector C1 (green).
we can take the power at the PDC (underhood fusebox) if i am correct.....
Update,
i checked the grey/pink wire(position 22) in the green connector at the bottom of the fusebox,
it's the right one, 12 volts at ignition and cranking, here we have to make the connection for the activation of the relay ( + 86) we can make al the connections in and around the fusebox, no need to route wires to the interior !
Permanently reset Fuse 11, this should do the trick ?-fusebox-connection-001.jpg
yves is offline
Old 02-12-2011, 08:38 AM   #34 (permalink)
Points: 42,369, Level: 1 Points: 42,369, Level: 1 Points: 42,369, Level: 1
Activity: 96% Activity: 96% Activity: 96%
Kaiser Bill's Avatar
Car: 2008 300c SRT-8 {LCC}
Member Number: 21130
wow, great work!
just hoping our loom is the same colour scheme - I know the rear light wiring for CRDs isnt the same as US models.....and of course its a pain for me because the fuse I want is in the trunk
Watching You Avoiding Me!
Kaiser Bill is offline
Old 02-12-2011, 02:53 PM   #35 (permalink)
Good job, have you wired yours up yet ? I couldn't find my caps , phoned a friend & he only had a 1farad cap ( a little on the large side) . If I get time tomorrow I will wire it to 86 & test it
PHASEONE is offline
Old 02-13-2011, 01:12 AM   #36 (permalink)
yves's Avatar
well,
here we go, back in an hour or two, gonna check the practical side NOW .
yves is offline
Old 02-13-2011, 02:27 AM   #37 (permalink)
yves's Avatar
Talking The RAW TEST version, it WORKS !!!!
relais ,with fuse 11 (don't judge me on the connexions, it is the "TRY IT OUT" version.)
yves is offline
Old 02-13-2011, 02:28 AM   #38 (permalink)
yves's Avatar
fusebox with wires coming from fuse 11
yves is offline
Old 02-13-2011, 02:29 AM   #39 (permalink)
yves's Avatar
earth
yves is offline
Old 02-13-2011, 02:31 AM   #40 (permalink)
yves's Avatar
pink/grey wire arriving at bottom connector in fusebox (green connector)
black wire spliced in to it going to 86 terminal of relay, (fused for security)
Permanently reset Fuse 11, this should do the trick ?-1rst-005.jpg   Permanently reset Fuse 11, this should do the trick ?-1rst-004.jpg
yves is offline
How-To: Stop dash rattles and squeaks permanently. dunsantos Tech Tips - DIY - How-To 9 07-28-2009 09:25 AM
Neat trick... saleen8927 General Discussion 11 03-31-2009 04:45 AM
Pull Fuse 11 PERMANENTLY? BuddyLee Performance General Discussion 6 10-21-2007 08:31 PM
Weird Chime after Fuse 11 reset???? FLAFIRE Problems / Dealer Service 2 06-19-2007 02:46 PM
Front Fuse Box --- 60 Amp Fuse SilverSea Problems / Dealer Service 7 12-09-2004 02:58 PM
