TESTED, IT WORKS !!! SRT8 Permanently reset Fuse 11,
if we cut fuse 11 (or use a blown one) and solder a wire to each side of the fuse,connected to a fused relay 30/87, operated by the ignition +,
every time we shut off the engine,the relay goes open , and does the same as removing fuse 11, or am i wrong on this one ?
Relay connections,
-30 wire to power side of fuse 11 in underhood fusebox
-87 wire to other side of fuse 11 in underhood fusebox
-86 to acc or ignition +
-85 to negativ (earth)
once the relay has power (+ on 86) it closes,connects 30 with 87, you have an OEM electrical circuit.
no power on +86 = open relay = no fuse connection. (same condition as fuse 11 removed)
it is even possible to use a fused wire in stead of a fused relay. (picture nr. 3)
only possible problem, are there other things connected to fuse 11 ?(checked the diagrams on fuse 11, i don't think it could give any problems whatsover)
looks good....I've thought about this quite a bit too. I considered wiring a switch to a Billet Technology console, but obviously, this solution is wholly automatic & probably pretty foolproof
__________________ Watching You Avoiding Me!
The Following User Says Thank You to Kaiser Bill For This Useful Post:
it would work , remove the fuse & run a wire from the fuse feed side by putting a spade terminal in the hole & connect to pin 86 of the relay , pin 85 to earth ,pin 87 back to the other side of the removed fuse ( with an inline fuse holder fitted with the removed fuse) , pin 30 to a permanent or ignition live (with an inline fuse ) , job done
2006 silver SRT8 sold
2007 silver SRT8 sold
Mercedes E55K AMG sold
Mercedes CL600 Bi Turbo V12 Sold
Sounds good, Phaseone want to come over later and take care of that for me? HA, I have no idea what you guys are talking about (conceptually I do.) Anyone want to guineau pig this one?
2006 300C SRT8, Vortech V-3 Supercharger, Predator CMR Custom Tune, Billet Technology Catch Can, Jet 180* Tstat, Black Mesh Emblem Grill, K/N CAI Intake, 10" Polk Subwoofer, 25% Tint all around, dropped 1" Traction Winter: Goodyear 20/40/245 RS-A Summer: Hankook V12 20/45/245MM front 20/45/275MM Rear.
Always open to new mod suggestions!
Best Track Run 1/4MI: 12.02 SEC @ 118.25MPH, (2.19 60FT)
Dyno Results 8/02/2012: 501RWHP 465TQ w/ Stock Tune/Pulley Vortech Supercharger
surely the original fuse is already accommodated in the relay? (i.e replacing the green fuse in the OP photo)
if you want one off the shelf, theyre £7:99 at Halfrauds....(robbers!) Ring RLFK 1230F
p.s. the trigger circuit has to go to an ignition 'on' supply. If you go to a 'permanent' supply as you suggest, the circuit never breaks, so the adaptive reset never happens. Does anyone know a possible place to solder on to, under the bonnet that goes live at ignition 'on' ?
