New Battery - Page 2 - Chrysler 300C Forum: 300C & SRT8 Forums
post #11 of 22 (permalink) Old 11-17-2012, 01:51 AM
Points: 67,563, Level: 1 Points: 67,563, Level: 1 Points: 67,563, Level: 1
UK CHRYSLER 300C's Avatar
13.8 is charging but it should be 14.2 no matter what on our cars(well that's what mine reads...)
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
post #12 of 22 (permalink) Old 11-17-2012, 02:27 AM
Elite Contributing Member
Points: 50,755, Level: 1 Points: 50,755, Level: 1 Points: 50,755, Level: 1
Once started it should be around 14.2v straight away and not move much from that with everything turned on, even on idle.
post #13 of 22 (permalink) Old 11-17-2012, 05:52 AM
Points: 18,477, Level: 1 Points: 18,477, Level: 1 Points: 18,477, Level: 1
Pappajohn's Avatar
I know charging is controlled by the EMU/ECU but is it via the front or rear PDC...or neither ?
the reason i ask is, i recently wired a 7 way by-pass to the rear PDC for towing and may possibly have disturbed some wiring/connection causing a poor joint.
Pappajohn is offline
post #14 of 22 (permalink) Old 11-17-2012, 11:49 AM
Pappajohn's Avatar
today i pulled every fuse in both PDC's, checked with a multi meter, replaced them a few times to clean the blades.
pulled every relay and treated the same as fuses then swapped them around like for like.
started the car....14.4v.
a little later it dropped to 12v.
turned off then restarted immediately and 14.8v
went shopping then started it again and 12,6v...turned off straight away and restarted...14.5v again.
I suspect an ignition switch fault or dirty terminal/loose wire.
post #15 of 22 (permalink) Old 11-17-2012, 03:11 PM
You need to get your alternator and connection from alternator to battery checked again. Charging is not controlled by ECM it is controlled by a regulator in the alternator.
Sorry even though you say alternator has been changed I think you will find you have a duff one.
Don't want to offend you but there is not the slightest possibility of it being the ignition switch. Take it back to whoever fitted the alternator and ask them to check it please.
Jack
jackwalton is offline
The Following User Says Thank You to jackwalton For This Useful Post:
badgx (11-17-2012)
post #16 of 22 (permalink) Old 11-17-2012, 03:18 PM
I would say voltage regulator too.
post #17 of 22 (permalink) Old 11-17-2012, 04:38 PM
Pappajohn's Avatar
Jack
thanks for the input.
just seem to much of a coincidence it works OK if i switch off and restart
fitted the new one myself and i aint taking it off again unless i really have to so i'll take it to the local alternator/starter specialists to be tested.
if it is a lemon I'll have no problem getting it exchanged...got it trade through my brother
post #18 of 22 (permalink) Old 11-17-2012, 04:49 PM
Sorry I take it back I was wrong. The regulator is not in the Alternator in the 300C it is in the PCM and the charging rate varies as the ambient temperature changes as sensed by the sensor.
Jack
post #19 of 22 (permalink) Old 11-17-2012, 05:18 PM
Pappajohn's Avatar
Jack
A little more info if you can Jack.
where is the sensor ?
is it a stand alone item or is it inbuilt into the PCM ?
I would have thought in colder weather (now) the charge rate would be higher than in summer.
just been out again (only 4 miles) and the voltage was again at 11.4v on startup and again crept up to 14.4v as the car, and obviously engine bay, warmed up.
post #20 of 22 (permalink) Old 11-17-2012, 05:48 PM
Sorry yet again, for PCM read ECM. Thinking logically, I assume it will be the sensor that displays on the EVIC ie outside air temperature, not the air intake temperature sensor.
See attached drawing for pin connection details to ECM. I still think it is likely to be the Alternator though.
Pappajohn (11-17-2012)
Which battery should I buy ? ivanford UK & Europe Regional Forum 28 02-02-2012 06:59 AM
Is my battery about to die? Surreyuk UK & Europe Regional Forum 10 09-17-2011 02:25 AM
RKG Battery joelatigo Problems / Dealer Service 4 10-15-2008 10:27 AM
Battery Down Jimmy General Discussion 1 11-11-2007 10:36 PM
second battery 300cWannaBe Car Audio/Alarms/UConnect/Navigation 2 10-17-2006 08:04 PM
