egr location on crd - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 22 (permalink) Old 11-22-2012, 11:44 AM Thread Starter
Points: 21,486, Level: 1 Points: 21,486, Level: 1 Points: 21,486, Level: 1
alex uk's Avatar
Car: 2006 chrysler 300c crd
egr location on crd
can anyone point out where the egr is for me please or if I could get a picture that would be even better I want to delete the egr this weekend
can anyone help please
alex uk is offline
post #2 of 22 (permalink) Old 11-22-2012, 12:23 PM
Elite Contributing Member
EGR valve is on LH side rear of engine under the plastic cover towards top of engine. (LH when viewed from drivers seat).
How do you intend to delete it ?
Are you going to fit a resistor to prevent EGR from opening or do you intend to attempt a delete from MAP.
They definitely run better when EGR remains shut. But if resistor is fitted in place of EGR you will get an error code thrown up and MIL light will come on.
Jack
jackwalton is offline
post #3 of 22 (permalink) Old 11-22-2012, 12:39 PM Thread Starter
alex uk's Avatar
thank you
I was going to try the resistor for now until I can get the cash together to get the map
alex uk is offline
post #4 of 22 (permalink) Old 11-22-2012, 02:32 PM
Points: 30,136, Level: 1 Points: 30,136, Level: 1 Points: 30,136, Level: 1
Kelvin's Avatar
Car: 2006 Chrysler 300C CRD
Send a message via Skype™ to Kelvin
I've never had the EGR valve off my engine. Is it possible to simply install a blocking plate over the egr port as was the case with many other engines?
Kel
Kelvin is offline
post #5 of 22 (permalink) Old 11-22-2012, 03:47 PM
Kel
As long as the EGR Valve is shut there is no need to blank it.
post #6 of 22 (permalink) Old 11-22-2012, 03:50 PM
Originally Posted by alex uk View Post
thank you
Will run much better with resistor fitted. Only problem will be is that the MIL light will come on after about 5 trips because the system will detect that there is low Gas flow/recirculation.
Jack
post #7 of 22 (permalink) Old 11-22-2012, 04:27 PM
Kelvin's Avatar
Thanks Jack, not sure if I could put up with the light being on all the time.
Kelvin is offline
post #8 of 22 (permalink) Old 11-23-2012, 02:47 AM
No I cant run with light on either because I would be concerned it would mask other problems.
Ive got resistor mod in place of EGR and my car runs much much better.
MIL light comes on after about 5 "Warm up from cold" so because I don't use my car much I just reset the Mil when it comes on and then wait for it to re-appear again (Dont know how practical this is for you, it depends how you use the car.
Ive found the error code, (P0401 EGR insufficient flow) that lights the Mil is activated during a warm up cycle when the Water Temp reaches about a quarter way up the temperature dial.
Jack
post #9 of 22 (permalink) Old 11-23-2012, 04:48 AM Thread Starter
alex uk's Avatar
I am still not sure what im looking for car anyone post a pic of where the connector for the egr is please
alex uk is offline
post #10 of 22 (permalink) Old 11-24-2012, 02:50 AM
Points: 53,121, Level: 1 Points: 53,121, Level: 1 Points: 53,121, Level: 1
The egr is located on the inlet manifold next to the turbo on the nearside off the car. Its a large cylindrical object with a plug on the end.
This is the only photo I can find showing the EGR (as I sold my CRD), its the item at the top of the photo that has a green dot on it.
Kelvin, they cannot be removed and blanked but are defaulted to closed position when unplugged.
Amp Location perky Car Audio/Alarms/UConnect/Navigation 3 07-08-2011 05:51 PM
bcm location? peter 0723 General Discussion 0 02-28-2010 03:34 PM
ddl location RHAMMERD General Discussion 5 07-25-2007 11:04 PM
Amp Location rudie1515 Car Audio/Alarms/UConnect/Navigation 7 10-11-2006 01:51 PM
