Average battery life? - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 51 (permalink) Old 12-24-2012, 11:21 AM Thread Starter
Elite Contributing Member
Points: 22,785, Level: 1 Points: 22,785, Level: 1 Points: 22,785, Level: 1
devilmaycare's Avatar
I'm trying to ascertain what the typical, or average, battery life might be for an original component as fitted to a new CRD. My original battery is now just over 6 yrs old and its starting to show signs of flagging; an indication being the appearance of the battery warning lamp, just after starting the engine. My initial thoughts were the dreaded alternator problem, so I did some voltage checks with TorquePro. With the warning light lit and the engine idling, the battery volts were only 11.9. After increasing the revs a bit, the light went out and the volts increased to 13.6 after a short time, but never reached the desirable 14.5 volts. So the alternator does seem to be charging. I then switched on the heated rear screen and the passenger seat heating and the 13.6 V was maintained. I have been using the car for fairly short trips, mostly at night and wondered if the battery was getting sufficient charge, or maybe, because of its age, the charge wasn't being retained - usually the tell-tale sign of a dying battery. My next move will be to put the trickle charger on and see what happens. However, I have noticed on the forum that several owners have replaced their batteries before 6 yrs have expired. The original battery on my Audi A4 1.9TDi lasted 9 yrs, but its replacement only lasted 5 yrs. My friend's BMW 3 series diesel still runs on its original battery after 10 yrs. So what are the expectations for a 300CRD battery?
devilmaycare is offline
post #2 of 51 (permalink) Old 12-24-2012, 11:28 AM
Points: 139,460, Level: 1 Points: 139,460, Level: 1 Points: 139,460, Level: 1
Activity: 27% Activity: 27% Activity: 27%
Car: Chrysler 300c 2009 CRD
From what i remember it seems to be 6-7 years, but not reaching 14v seems a bit iffy to me.
paul@thecustom300cshop is offline
The Following User Says Thank You to paul@thecustom300cshop For This Useful Post:
devilmaycare (12-24-2012)
post #3 of 51 (permalink) Old 12-24-2012, 11:42 AM
Points: 139,023, Level: 1 Points: 139,023, Level: 1 Points: 139,023, Level: 1
badgx's Avatar
9 years, wow that's very good service How many miles were you able cover with the original battery in those years?
badgx is offline
post #4 of 51 (permalink) Old 12-24-2012, 11:53 AM
Points: 2,693, Level: 1 Points: 2,693, Level: 1 Points: 2,693, Level: 1
kugabooga's Avatar
Car: 2008 chrysler 300c Touring
Hey there,
I've just replaced mine 2008 CRD @ 33000 miles , it was showing signs of faltering.Cold mornings were really taking their toll on the battery as they do .
Now got a Bosch 100Ah from Halfrauds ( was stuck for choice ) .
cheers
The early bird gets the worm
...................But the second mouse gets the cheese !!
kugabooga is offline
The Following User Says Thank You to kugabooga For This Useful Post:
post #5 of 51 (permalink) Old 12-24-2012, 11:57 AM Thread Starter
121,000 - I've just checked the MOT Cert. for the month following replacement. I think the original battery was a Bosch.
post #6 of 51 (permalink) Old 12-24-2012, 12:11 PM Thread Starter
This is why I want to try trickle charging to see if that makes any difference. From past experience, a duff battery will often not show the desired voltage, even after an extended charging period. According to the workshop manual, before attempting to diagnose low battery volts and potential alternator problems, it is recommended to check the battery condition.
post #7 of 51 (permalink) Old 12-24-2012, 12:30 PM
badgx's Avatar
I would check the concentratino of the battery acid with a hydromoter tester, only costs a few quids and top up with distilled water if necessary. If applied a heavy load tester, a good battery should not bubble within the cells. When it goes the tale tale signs depending on how bad each cell has become will often bubble and give off a egg smell. Its a good way of checking the condition of each cell
badgx is offline
The Following User Says Thank You to badgx For This Useful Post:
post #8 of 51 (permalink) Old 12-24-2012, 12:55 PM
Points: 2,631, Level: 1 Points: 2,631, Level: 1 Points: 2,631, Level: 1
Car: 2006 chrysler 300c
Just had to replace mine a few cold mornings killed it, it was an original 6 years old.
Cycled to work once that was enough.
Brian.
K1 BPS is offline
The Following User Says Thank You to K1 BPS For This Useful Post:
post #9 of 51 (permalink) Old 12-24-2012, 01:06 PM
Ctek battery condition chargers have a conditioning function built in that can often revive a failing battery if the problem is due to sulphation of the plates. Ctek chargers cost between £30 and £40 though. Cheaper equivalents are sometimes available at Lidl or Aldi for about £15.
Not very practical if you havnt got quick access to one though when you have problems, but worth a try if you have one.
Jack
jackwalton is offline
The Following User Says Thank You to jackwalton For This Useful Post:
post #10 of 51 (permalink) Old 12-24-2012, 01:26 PM
Jack
True i have a ctek charger and is very good, they charged a few batteries in the past that a standard charger wouldnt charge
Average Age?? corfew UK & Europe Regional Forum 96 03-23-2013 09:34 AM
Life of the Battery Kelvin Australia / NZ Forum General Discussion 18 09-07-2010 01:06 AM
Battery Life (Moved) 30c General Discussion 2 12-31-2008 04:46 PM
Battery Life 2006 300C Larryt General Discussion 13 03-06-2008 12:58 PM
Real average MPG? SSpray 1st Gen SRT8-Specific General Discussion 22 07-27-2006 07:04 AM
