Front Fog Bulbs - Page 2 - Chrysler 300C Forum: 300C & SRT8 Forums
post #11 of 31 (permalink) Old 01-18-2013, 10:30 AM
Points: 7,981, Level: 1 Points: 7,981, Level: 1 Points: 7,981, Level: 1
Sonsarus Amaryllus's Avatar
Car: 2007 Chrysler 300c Touring, 1998 Sebring Convertible
Originally Posted by Jimmyboy View Post
These would be ideal. probably closer in colour to your dip headlights but would be slightly dimmer than clear xenon. D
Sonsarus Amaryllus is offline
post #12 of 31 (permalink) Old 01-18-2013, 11:41 AM
Points: 69,686, Level: 1 Points: 69,686, Level: 1 Points: 69,686, Level: 1
UK CHRYSLER 300C's Avatar
You don't need any capacitors or anything else for HIDs in fog lamps,straight forward swap,you may need HID correcters for main beam HID conversion unless you buy canbus friendly kits,I bought mine years ago before canbus friendly kits were made so I bought HID correcters but fog lamp conversion doesnt need anything as they're not ran by canbus
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
UK CHRYSLER 300C is offline
post #13 of 31 (permalink) Old 01-18-2013, 11:59 AM
Points: 146,940, Level: 1 Points: 146,940, Level: 1 Points: 146,940, Level: 1
badgx's Avatar
Its the same thing, its basically a small plug contains a capacitor that is wired up with a resistor. The capacitor helps stop the flickering and the resistor makes it canbus friendly.
The fogs on ours are NOT on canbus but you will need it if you want the fog to come on with the headlights on entry set on timer mode after pressing key fob. Well the kit on mine, the evic needed it, so added it
Here a link to fleabay, its only a few quids
2 X HID Error Code Warning Canceller Capacitor Decoder | eBay
badgx is offline
post #14 of 31 (permalink) Old 01-18-2013, 12:08 PM
Points: 15,687, Level: 1 Points: 15,687, Level: 1 Points: 15,687, Level: 1
esgyrndafydd's Avatar
Car: 2006 Chrysler Midnite Blue 300c CRD Touring
Just been looking at the manual to see what sort of a job it is to swap the fog bulbs...
Hmmm
I think I'll leave them as they are.
David Kennedy
EGR Valve (35k), Swirl Motor and seals(55k), Billet Tec catch can (60k), MTEC discs, calipers, EBC pads, handbrake shoes and all fittings (75k), new inlet gaskets and turbo seals [again] (90k) ,re-built front suspension, new alternator and shield (100k) New n/s front door handle
esgyrndafydd is offline
post #15 of 31 (permalink) Old 01-18-2013, 12:10 PM
Fog lamps on ours,well mine anyway,are not canbus,they're relay fed,so no crap needed to make them work,full beam however is canbus fed and because the amps and volts are lower on HIDs the ECU thinks a bulb is going down so it turns it off after a flicker or three cos it thinks there's a problem ( on non canbus friendly kits like mine) canbus friendly kits are plug n play
post #16 of 31 (permalink) Old 01-18-2013, 12:13 PM
Hmmm
Lol....piece of cake but you will need some new clips for the sh1tguard to clip into the wheel arch edge of the wing properly
post #17 of 31 (permalink) Old 01-18-2013, 12:20 PM
badgx's Avatar
Yup, the capacitor kits are all plug & play, ideal for non canbus HID kits. As above, you will need it if you want the fogs to light up on entry i.e. 30 second timer with the headlights
The only bit is how to access to plug it all in together. Some folks like to access from underneath by removing belly pan.
For me, I just turn the road wheel fully left lock and open up the splash back a little to allow access to change the fogs on the offside and then fully right lock to change the fogs on the nearside. It takes 5 mins to do each side & you can mount the ballast anywhere clean using 3M double sided peel backs are strong enough
badgx is offline
post #18 of 31 (permalink) Old 01-18-2013, 12:25 PM
Oh....so they are plug n play now ay.....lol
post #19 of 31 (permalink) Old 01-18-2013, 01:58 PM
Points: 3,531, Level: 1 Points: 3,531, Level: 1 Points: 3,531, Level: 1
Jimmyboy's Avatar
Car: 2006 chrysler 300C crd
When you say full beam do you mean dipped beam? as full beam bulbs aint HID??
Jim.
Jimmyboy is offline
post #20 of 31 (permalink) Old 01-18-2013, 02:11 PM
I mean convert them to HID ......and the fogs
9005 Super High Output SMT Bulbs (Led Bulbs) uncj21 Lighting Discussion 1 08-25-2009 09:45 PM
How To Replace Interior Stock Bulbs To LED Bulbs? SoSick300 Lighting Discussion 1 11-08-2007 12:57 PM
front fog light bulbs Derek Mc Lighting Discussion 11 08-09-2007 10:24 PM
EXPIRED: Xenon Bulbs - High & Low bulbs - Fit stock headlight! asking $40 BIGBODY300 Parts Buy/Sell Forum 0 03-31-2007 07:34 AM
LED tail light BULBS replacement BULBS? Tork Monster Appearance General Discussion 5 08-16-2006 02:35 PM
