diy servicing options - Page 4 - Chrysler 300C Forum: 300C & SRT8 Forums
post #31 of 69 (permalink) Old 02-26-2013, 05:25 AM
Points: 4,312, Level: 1 Points: 4,312, Level: 1 Points: 4,312, Level: 1
I'll see how much the ESP is with my Halfrauds trade card. Any opinions on "vacuum through dipstick" vs oil pan drain, as I'll want to order a new plug with filters if the vacuum technique isn't good for the cars (I'm guessing this is what the dealers do though, and it's what I do with my SLK).
RichardTK is offline
post #32 of 69 (permalink) Old 02-26-2013, 06:39 AM
Elite Contributing Member
I think a lot of dealers do use the "sucking" method now.
I recently bought a "sucker" but havn't used it yet (Summer Job).
I'm sure its not the best method, but if the oil is reasonably clean rather than looking obviously the worse for wear and sludged up I think its a case of "I think I can get away with sucking it out".
If anyone is hanging onto thier cars for a long time though I am sure a proper drain would be best every few oil changes.
Jack
jackwalton is offline
post #33 of 69 (permalink) Old 02-26-2013, 07:20 AM
Points: 9,563, Level: 1 Points: 9,563, Level: 1 Points: 9,563, Level: 1
Petman's Avatar
Car: 2006 Chrysler 300c CRD
I have a oil sucker too, well I have to, we have a Smart car (no sump plug) and I now use it on all cars.
The first time I used it I also opened the sump plug to see it was getting all the oil out On the cars I have tried, including 300c's all the oil is removed and I only got a few drops from the sump plug. Oil and filter changes on the C are now very easy, just make sure the engine is warm before you start sucking
Petman is offline
post #34 of 69 (permalink) Old 02-26-2013, 08:52 AM
Points: 19,448, Level: 1 Points: 19,448, Level: 1 Points: 19,448, Level: 1
Car: 2015 Chrysler 300c Executive Silver
I'm keen on the sucking idea , all that fannying around with splash guards, worn and rounded hex sump plugs, and scurrying about underneath the car and you still make a oily mess on your nice mono-block driveway.
How much are these things anyway ?
jeyaar789 is offline
post #35 of 69 (permalink) Old 02-26-2013, 09:14 AM
Mine's a laser one and was about £50. Works very well on the cars I've used it with - I could change oil on the MX5 in 10 minutes even allowing for scalding my wrist getting the filter out!
post #36 of 69 (permalink) Old 02-26-2013, 10:44 AM
Points: 24,619, Level: 1 Points: 24,619, Level: 1 Points: 24,619, Level: 1
devilmaycare's Avatar
I used a Pela pump for the first time on my 300C last year. Works fine, very clean and easy and overcomes the problem of having 9 litres of oil gushing out of the sump. I've been using the pump for several years now on my Audi with no problems. As for the critics who raise the issue of sludge removal, if it can't be sucked out, its unlikely to flow through the sump hole either. If the engine is warmed up first, hopefully any sludge should be in suspension anyway. Another advantage of the pump is that you can suck out about 250ml from the filter housing, which wouldn't drain through the sump.
devilmaycare is offline
The Following User Says Thank You to devilmaycare For This Useful Post:
dm575 (02-26-2013)
post #37 of 69 (permalink) Old 02-26-2013, 11:17 AM
Ordered a pump today, plus oil and a filter, I'll be doing my oil changes from now on.
I'm suspicious of what unknown gunk my garage are putting in my engine.
For those in Scotland this looks a fair deal, they have a store in Port Dundas, Glasgow.
5w 30 GENUINE GM VAUXHALL BMW FULLY SYN. ENGINE MOTOR OIL 5L DEXOS 2 | eBay
post #38 of 69 (permalink) Old 02-26-2013, 12:04 PM
Points: 3,293, Level: 1 Points: 3,293, Level: 1 Points: 3,293, Level: 1
royliz's Avatar
Car: 2010 (EYO) chrysler 300c crd touring
personally check vauxhall dealer prices but ask for 4x5litre cans enough for 2 oil changes
Roy
royliz is offline
post #39 of 69 (permalink) Old 02-26-2013, 03:07 PM
Points: 146,940, Level: 1 Points: 146,940, Level: 1 Points: 146,940, Level: 1
badgx's Avatar
I like the good ol'fashion drain plug method, gives me an opportunity to inspect the underneath
You can reuse the drain plug a few times as long as the rubber has not been too squash, they did away with the cooper washers but you can get aftermarket magnetic sump plugs on ebay.
badgx is offline
post #40 of 69 (permalink) Old 02-26-2013, 03:24 PM
badgx's Avatar
Can't remember but I think the thread size on the hemi is M14 X 1.5, for the sump plug but might be different size for the Mercedes
badgx is offline
Servicing Costs mymobile Australia / NZ Forum General Discussion 318 09-20-2013 07:23 PM
Servicing ? jeyaar789 UK & Europe Regional Forum 5 08-25-2012 12:44 PM
Car servicing the way you want it. huskydog Australia / NZ Forum General Discussion 32 03-28-2010 04:57 PM
CRD Servicing every 20000K Roadrunner Australia / NZ Forum General Discussion 7 10-28-2008 04:23 AM
