EVIC fuel tank values - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 19 (permalink) Old 02-26-2013, 03:33 PM Thread Starter
Points: 19,520, Level: 1 Points: 19,520, Level: 1 Points: 19,520, Level: 1
Pappajohn's Avatar
where do i start ?
the fuel menu states.....left tank = 191....right tank = 190
my understanding this is in US pints ?
191 US pints = 23.88 US gallons
the EVIC says 19.* gallons
the other tank says 190
that is another 23.75 gallons
23.75 US gall is 19.88 imp gall...near enough what the EVIC states as a total
where does the other 191 come from...surely the car doesnt have a 47.63 US (39.66 imp) gallon tank !!!
my 7.5ton motorhome tank only holds 70 US gallons.
the EVIC appears to have a mix of US pints and imp gallons.
very confusing.
Pappajohn is online now
post #2 of 19 (permalink) Old 02-27-2013, 03:12 AM
Elite Contributing Member
Originally Posted by Pappajohn View Post
where do i start ?
very confusing.
You have maybe found a way to make fuel ??? lol
Seriously though. My EVIC displays fuel content in Ltrs.
Why dont you change the units to "metric" display and see how you go, and if it makes more sense.
There is no sense at all in diplaying US Gallons if you have other options. Unless your a Yank living on the east coast of Yorkshire.
Jack
jackwalton is offline
post #3 of 19 (permalink) Old 02-27-2013, 04:55 AM Thread Starter
Pappajohn's Avatar
thanks Jack, but changing to litres wont alter the fact the values are incorrect, it will still add up to the same only in metric.
and changing to metric will also change all the other values...speed in KPH, consumption in ltrs/100km, TPMS in kpa etc (not that that will affect me)
not that concerned as i know how much fuel i put in and how far i,ve driven but the point is the values are wrong.
post #4 of 19 (permalink) Old 02-27-2013, 07:35 AM
Mine actually shows the unit of measurement which is Ltrs. Wonder why yours doesnt ??
I dont have any US displays on mine.
Your assumings its US pints but may not be.
Just keep using the free fuel your car is making. Lol
I meant just try changing to metric to see what it displays and see if it shows the unit of measurement. Then change it back.
Mine shows mph not km , but shows ltrs on fuel level.
Jack
post #5 of 19 (permalink) Old 02-27-2013, 11:57 AM Thread Starter
Pappajohn's Avatar
tried swapping to metric Jack.
only thing that changed in the fuel screen was the current mileage, shown at the bottom of the screen in question, changed to km
all the other digits remained the same.
the minL and minR figures are actually 199 left and 200 right
even if only one f the above figures applied and it did show litres that would mean the car has a 44 gallon tank.
none of the figures make any sense, but then neither does the oil pressure reading as we know.
post #6 of 19 (permalink) Old 02-27-2013, 12:30 PM
Ive got to opologise yet again. Sorry, sorry ,sorry I don't know what I'm on about half the time.
Just been out to check mine because as most people I havn't paid any attention to it.
I was going from memory and just THOUGHT mine showed the units as Ltrs , but it doesnt. (Ive just been and checked). Its interesting, what you have found.
Havn't checked out all figures on EVIC yet, just had a quick check for unit of measurement.
Will check mine sometime and let you know what mine actually says rather than guessing what it says.
Sorry,
Dont forget to keep using the free fuel though.
Jack
post #7 of 19 (permalink) Old 02-27-2013, 12:51 PM Thread Starter
Pappajohn's Avatar
I'm trying to get enough free fuel to fill my m/home's 70 gallon tank ;-)
if you do figure it out, give Chrysler a ring and explain to them...'cos they probably dont know either.
post #8 of 19 (permalink) Old 02-27-2013, 01:37 PM
Hi again,
Can throw a bit of light on it.
The MinL and MinR values you mention are NOT volume of fuel but I think they are some kind of calibration factor that Chrysler input to get the indication they want. Mine displays 180 and 181 with tank 3 quarter full.
The numbers you need to read that show the fuel volume remaining are the numbers directly below the MinL and MinR. Mine reads 64 & 47 = 111 US Pints * 0.104084273
which equals 11.5 galls (which is somewhere near correct). Levels are difficult to measue acurately, and volume even more difficult because of the shape of the tanks. Dont think its possible to accuratley work out. Its just a guide and as long as top and bottom is about right, you accept the errors inbetween)??
19g Displayed = 19 Gallon Tank
Avg=Total of fuel (Adds Left and Right Tank Quantity) ITS NOT actually an average.
If you get someone to shake the car about and watch the EVIC you can see the levels changing on the numbers below the Minl and MinR but the other numbers dont change.
By the way.: JUST NOTICED THAT MY OIL PRESSURE READING ON EVIC SHOWS A GOOD OIL PRESSURE OF 115Kpa WITHOUT ENGINE TURNING OVER. VERY GOOD EH. EVEN GOT GOOD OIL PRESSURE FROM NOWHERE AS WELL AS FREE FUEL.
Jack
post #9 of 19 (permalink) Old 02-27-2013, 03:40 PM Thread Starter
Pappajohn's Avatar
that must be another fixed 'variable' then Jack.....
mine shows 115PSI engine running or not
there was a recent thread regarding this....the CRD doesn't have a pressure switch of any type.
incidently, my Lmin/Rmin always shows 199/200 no matter how full/empty the tank is.
the only changes are the two figures below that (left tank/right tank) when cornering etc, and the average fluctuates, which is normal. !
also...if these two figures (usually only the left tank) show a total of 20 and i put in another 20ltrs the figure doesnt total 40...it can be a random number, usually around 55/57.
I reckon this is another uncalibrated function which Chrysler cant be bothered with.
need to look under the bonnet tomorrow as well, getting the occasional whiff of burning oil coming through the heater vents.
post #10 of 19 (permalink) Old 02-28-2013, 01:18 AM
Points: 68,105, Level: 1 Points: 68,105, Level: 1 Points: 68,105, Level: 1
UK CHRYSLER 300C's Avatar
Jack.....stop talking sh1t, our tanks are 72 litres,well mine is anyway and thats about 16 gallons not 19....you make me laugh....lol
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
UK CHRYSLER 300C is offline
Fuel Tank Capacity padpadpadpad UK & Europe Regional Forum 36 05-04-2015 03:04 PM
Fuel Tank need to change kalo's 300C Problems / Dealer Service 0 11-23-2010 09:45 PM
Is there a way I can take some fuel out from the tank? Prozac General Discussion 9 10-30-2010 07:23 AM
Fuel Tank Capacity Roger V UK & Europe Regional Forum 13 07-27-2006 03:40 PM
Fuel tank moparfo 1st Gen SRT8-Specific General Discussion 15 03-27-2006 09:02 AM
Replace with
