Good Oil anyone? - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 19 (permalink) Old 02-09-2017, 10:04 AM Thread Starter
Points: 9,499, Level: 1 Points: 9,499, Level: 1 Points: 9,499, Level: 1
feichter's Avatar
Car: 2007 Chrysler 300C CRD
Good Oil anyone?
Hi All
My 3.0 CRD is due a service and MOT next month. I normally supply the garage with my own oil. Anyone know of any bargains out there at the moment?
Thanks
feichter is offline
post #2 of 19 (permalink) Old 02-09-2017, 12:04 PM
Points: 8, Level: 1 Points: 8, Level: 1 Points: 8, Level: 1
Not massively sure as I don't have a diesel (see thread below 3.5 v6 oil) I do believe that moobil will do the trick. Others mention GM spec Vauxhall.
Opie oils are a good place but also eurocarparts with their discounts. Google opie
For other motors I've always liked eurocarparts own brand triple qx. Very good value and made by shell I think, served me very well in many rovers (that had a range of rover, bmw and Honda lumps in). Only reason I'm hunting for something else is that my petrol beasty demands strange American oils.
Gazza487 is online now
post #3 of 19 (permalink) Old 02-09-2017, 03:48 PM
Points: 8,837, Level: 1 Points: 8,837, Level: 1 Points: 8,837, Level: 1
Car: 2010 Chrysler 300C
Mercedes Benz 5W30 is available on ebay - if you've storage space for a 20L container, it's £53.99 for 20L which would do two services. Otherwise it's £35.18 for 10L.
talldave is offline
post #4 of 19 (permalink) Old 02-09-2017, 05:56 PM
DGO
Points: 7,898, Level: 1 Points: 7,898, Level: 1 Points: 7,898, Level: 1
Car: 2008 Chrysler 300c CRD
Vauxhall Dexos2 5w30 from your local Vauxhall garage
DGO is online now
post #5 of 19 (permalink) Old 02-11-2017, 05:57 AM
Elite Contributing Member
Points: 23,773, Level: 1 Points: 23,773, Level: 1 Points: 23,773, Level: 1
Activity: 40% Activity: 40% Activity: 40%
devilmaycare's Avatar
If you're going to the trouble of getting your own oil, why not get the filter as well and do the job yourself? Oil changes on the CRD are the easiest on any car I have ever owned. Get a pump to remove oil via the dipstick - the MB engine is designed for that. The filter bowl is at the top of the engine, near the rad, but to do the job properly you will need the special tool (fleabay) to remove/replace/torque the cap. No crawling underneath - you could do the job in your Sunday Best! Changing the pollen filter is even easier. Also, fuel and air filter replacements are very straightforward. I have used both Dexos2 and MB oils as recommended in earlier posts; total cost of oil change = £41, including £6 filter from Eurocarparts.
devilmaycare is offline
post #6 of 19 (permalink) Old 02-12-2017, 05:36 AM
I'll second that, I did my last service myself after buying the necessary tools. The hardest part was dealing with the clips on the fuel filter, even with the right tool they're a bit fiddly as a first timer! The oil change, as devilmaycare says, can be done without spilling a drop. I went mad on a genuine MB oil filter for £11!
talldave is offline
post #7 of 19 (permalink) Old 02-12-2017, 06:19 AM
I replaced the original fuel filter clips with the nut and bolt type, to make future changes easier. Needed two different sizes to correspond to the different input/output hose sizes.
post #8 of 19 (permalink) Old 02-16-2017, 12:11 PM Thread Starter
feichter's Avatar
Thank you all for your support and encouragement!
feichter is offline
post #9 of 19 (permalink) Old 02-16-2017, 12:23 PM
DGO
Have just come across this: https://www.gsfcarparts.com/980aa0381 which claims to be MB229.31 and 229.51 standard which with a 40% off code (pm me if you want a link) comes out at just over 30 pounds for 9 litres
DGO is online now
The Following User Says Thank You to DGO For This Useful Post:
feichter (02-17-2017)
post #10 of 19 (permalink) Old 02-17-2017, 05:55 AM
DGO
Even better this weekend with their 50% off code "BRR50"
DGO is online now
Hemi motor oil leak/ Rear main seal leak/ bridge loose MUST READ! badasblkhemi300c General Discussion on Issues / Trouble Shooting 1 01-11-2017 06:24 AM
2015 V6 Oil Change question 2k15on22s 2nd Generation Chrysler 300 Discussion 13 10-25-2016 01:17 PM
Oil pressure problem 300c 5.7 redcatcher General Discussion 1 08-14-2016 11:45 AM
Oil Pressure Sensor - Failed Again?? larryntripp General Discussion on Issues / Trouble Shooting 3 12-06-2015 11:27 AM
Oil everywhere jdbrassell 2nd Gen SRT8- Mechanical 8 10-01-2015 07:14 AM
Replace with
