Gearbox plug/Seal - Page 3 - Chrysler 300C Forum: 300C & SRT8 Forums
post #21 of 39 (permalink) Old 09-30-2011, 10:51 AM
Points: 422, Level: 1 Points: 422, Level: 1 Points: 422, Level: 1
Car: 2007 CHRYSLER 300C
Thanks mate , I kinda thought that was the case. Think i'll taake this one on myself............probably be looking for the "blown gearbox" thread next week but heyho, i'll give it a go
MarkWright is offline
post #22 of 39 (permalink) Old 10-01-2011, 01:06 AM
Points: 68,105, Level: 1 Points: 68,105, Level: 1 Points: 68,105, Level: 1
UK CHRYSLER 300C's Avatar
it's a piece of p1ss to change,it's like an adaptor/extension plug with the seal,you lose a bit of oil but as Chrisp says you could put back in what came out,the dipsticks the only way really as if it was leaking you don't know how long it's been leaking and how much
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
UK CHRYSLER 300C is offline
post #23 of 39 (permalink) Old 10-03-2011, 04:47 PM Thread Starter
Points: 68,052, Level: 1 Points: 68,052, Level: 1 Points: 68,052, Level: 1
chrisp's Avatar
Car: 2006 Chrysler 300c SRT-8 {SZZ}
Heres the updated "Pilot Bushing" as MB call it. As UK says easy to fit. Just turn the locking collar to 7 o clock position and remove the wiring plug. Next undo the 7mm bolt in the centre of plug pull the old bushing out off the box carefully catching the oil you've lost. Next lube the o rings on the new plug with a smear of ATF line up the new plug( it will only go one way) push the plug into the box and nip up the 7mm bolt (not to tight its only plastic) Reinsert the wiring harness plug pushing the locking collar back to 11 o clock to lock it in. Youre now done underneath. If you havent had a major leak ie nothing dropping on the floor top back up with what you caught when removing plug (make sure you keep it clean). If you have had a dramatic loss of fluid you will need to check the level with a dipstick as UK recommends. Or failing that get a stealer to check the level.
MOPAR OR NOCAR 440 Coronet
2006 SRT8 Diablo Predator 93 Octane CAI performance tune
Mopar Cold Air Intake
EBC Yellows
Hurst Shifter
Badlanz Cutouts
Magnaflow Catback System
chrisp is offline
post #24 of 39 (permalink) Old 10-05-2011, 03:06 PM Thread Starter
chrisp's Avatar
Heres the TSB for reference
chrisp is offline
post #25 of 39 (permalink) Old 10-13-2011, 03:34 PM Thread Starter
chrisp's Avatar
Bit of an update about this job being easy lol. Did my second one of these in as many weeks on a 2007 CRD today. Over the pit we go. What they like to do he says piece of p##s says me. I'll be done in ten minutes go and make a brew. So out comes the wiring plug undo 7mm bolt pull out the old bushing catch fluid bit of a clean up lubed up new plug seals with a smear of ATF and in we go with the new bush. Or rather not, no matter how much i tried the b##stard would not go in far enough to let the 7mm bolt start. You know the scenario take it back out clean up lube O rings put back in after about 10 attempts im thinking f##king things never going to go in. Voice from above says your teas up here hows it going It f##cking aint says i. Finally i take the O rings off roll them over on themselves put them back on and this time lubed them with a smear of silicone grease result ?? b##stard went straight in. Just an afterthought bit of advice if have a problem getting these updated bushings in.
chrisp is offline
post #26 of 39 (permalink) Old 10-13-2011, 05:05 PM Thread Starter
chrisp's Avatar
This car belongs to a friend of a friend he's owned it for 2 years and has never looked after his cars. It had 32,000 miles on it when he bought it now on 108,000. He never washes it drives it in all wind and weathers the wheels are filthy but perfect no corosion whatsoever (bl##dy marvellous).It has no service history and has only had 2 oil changes since he's owned it both done by me. When i changed the oil & filter for him the first time at 75000 i pulled the cover and checked the turbo inlet pipe there was more oil round it and down round the swirl than the Torre Canyon deposited on the Cornwall coast. I told him this would need sorting oh it will be alright he said. Just done the oil & filter again along with the gearbox leak checked round the swirl again and still has bad as ever!! "Swirl port failure and oil contamination dont believe it LOL
chrisp is offline
post #27 of 39 (permalink) Old 11-15-2011, 01:04 AM
Points: 45,737, Level: 1 Points: 45,737, Level: 1 Points: 45,737, Level: 1
PHASEONE's Avatar
Car: . Lincoln Town car
I did an oil change on mine at the weekend & noticed mine was starting to leak at just 11400 miles , I still had the spare so just swapped it out . When fitting the new plug if you do the 7mm bolt up even a fraction to tight it must distort the outer housing as the wiring plug will not go back in no matter what . Ive added a few pics , not that great but I did the swap on the floor . The plug housing in the picture is the old one & thats the amount of oil that came out while doing the swap .
Name:	plug with loom.jpg
ID:	38853   Click image for larger version
ID:	38854   Click image for larger version
Name:	new plug fitted.jpg
ID:	38855   Click image for larger version
2006 silver SRT8 sold
2007 silver SRT8 sold
Mercedes E55K AMG sold
Mercedes CL600 Bi Turbo V12 Sold
Mercedes CLS500 AMG sold
Lincoln town car
PHASEONE is offline
The Following User Says Thank You to PHASEONE For This Useful Post:
Next Phase (11-19-2012)
post #28 of 39 (permalink) Old 11-15-2011, 02:44 PM Thread Starter
chrisp's Avatar
Thats the amount that drained out of mine fair play for doing it on the ground (bit of a struggle??)
chrisp is offline
post #29 of 39 (permalink) Old 11-15-2011, 03:27 PM
PHASEONE's Avatar
Let's just hope the wife doesn't notice her Pyrex jug !
PHASEONE is offline
post #30 of 39 (permalink) Old 11-15-2011, 03:49 PM Thread Starter
chrisp's Avatar
Washed up and back in the cupboard??? lol
chrisp is offline
Gearbox Oil tillman UK & Europe Regional Forum 21 03-23-2013 03:42 PM
Thumping Gearbox Kaga UK & Europe Regional Forum 5 11-11-2010 11:18 AM
gearbox question lancs uk bloke UK & Europe Regional Forum 5 10-12-2009 12:57 PM
Gearbox problem SarahSRT8 1st Gen SRT8-Specific General Discussion 5 10-02-2008 03:15 AM
Fuse 11/ gearbox Rgr UK & Europe Regional Forum 6 01-13-2008 04:36 PM
Replace with
