Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Supporting Vendors > Universal Air Suspension
Old 06-14-2006, 11:25 AM   #31 (permalink)
Member Number: 5047
Originally Posted by A7594217
Thanks for the response. Just one more ?, how far is san bernadino from the bay area(san francisco)
Its quite a drive, we are down here in so cal.
-Zack Ratcliff
800-864-2470
Old 06-14-2006, 11:38 AM   #32 (permalink)
Member Number: 5047
Originally Posted by CHUCHE13
whats the difference between running your front strut bags or air cylinders? MIC runs air cylinders.
There is a few downsides to cylinders in general.
1. Moving seal inside, allot shorter life span.
2. You are removing the shocks, you will never have the same ride quality/handling.
3. Air cylinders make noise.
4. Higher pressure to lift, less load cap.
5. Very sensitive to the elements.
6. Water/rust/debit damages seals inside cylinders.
The main advantages to cylinders in general.
1. Ease of install with right brackets
2. Lower cost for over seas cylinders
3. Fit inside smaller spaces (i.e. Honda's)
Typically general rule of thumb. If you can run an air bag definitely go with it. If the bag's will not fit you have to run air cylinders. Thats why no manufactures with O.E.M. Suspension run air cylinders, Yet, Several use air bags.
-Zack Ratcliff
800-864-2470
Old 06-14-2006, 12:13 PM   #33 (permalink)
Mr.DJ's Avatar
Car: 2005 Chrysler '300 Touring'
Member Number: 1464
Originally Posted by UniversalAirSuspension
To let you guys know if you want a visual of how air suspension works and a little about the 300C kit Click Here to view the special we did with The History Channel.
Great video...thanks.
~ Please visit my photo gallery ~
~ Please come visit us over at www.ChallengerTalk.com ~
Mr.DJ is offline
Old 06-14-2006, 12:58 PM   #34 (permalink)
DUBSTER's Avatar
Car: 2005 CHRYSLER 300
Member Number: 4939
Originally Posted by RAKilla
What pressure is everyone running front and back for everyday driving?
This is just cruisin height!! 48's in the front and 37's in the rear. On the highway it's 52's in the front and 50's in the rear.
DUBSTER is offline
Old 06-15-2006, 03:38 AM   #35 (permalink)
RAKilla's Avatar
Car: 2006 Chrysler 300T
Member Number: 3356
I'm guessing your talking psi in each bag, as in your running a fbss system. I set mine up to just be front to back.
RAKilla is offline
Old 06-15-2006, 08:42 AM   #36 (permalink)
4u2nv's Avatar
Car: 2005 Roe edition 300c
Member Number: 4087
Dubster, I'm a little bit confused. If I run 48psi in the front, there is no way I would be able to turn the wheel. Are you talking about 48psi? Or am I missunderstanding? Just curious. The very lowest I can go in the front with out hitting the fender when turning is about 90psi. I can go as low as 40 in the rear, but it will defenetly hit the well at every bump. I only do 90 in front and 40 in the rear if I'm cruising through a parking lot at a car show or cruise night or something.
4u2nv is offline
Old 06-15-2006, 11:29 AM   #37 (permalink)
Member Number: 5047
Dubster, have sandy's go in and change the settings in the gauge from the 145 senders to 400 psi senders.
-Zack Ratcliff
800-864-2470
Old 07-30-2006, 10:40 PM   #38 (permalink)
Black 300C's Avatar
Car: 2006 Brilliant Black Chrysler 300C
Member Number: 4068
Send a message via AIM to Black 300C
Miami Install
Zack, do you know of anybody in the Miami,Fl. area you can reccomend to do a UAS install?
Cliff RemStart,22"Sequence Rims,E&G DualWeave
Grillw/lower inserts,Chrome Dub Air Intake,Flashpaq
22Elite ArmRest,HemiC FloorMatsFront Back &
trunk,UltimatePedalsEngraved,Eibach ProSprings
Magnaflow Exhaust,5%Tints,Custom License,Dub badges,Sunroof,UConnect,Adjustable Pedals,Chrome Pillars,Clear Sidemarkers,LED bulbs&blinkers everywhere inside & out, Streamline Visor stickers,GSM Fan/Torque Mod,8000K HID Lowbeam & Fogs, BT Polished Wing Emblems,ipod integration,nav2go conversion,DVD & backup cam
Black 300C is offline
Old 07-31-2006, 11:39 AM   #39 (permalink)
Member Number: 5047
I have a few for you to check out.
Kreative Kustoms - 786-242-0034
Smart Sounds - 305-378-4020
-Zack Ratcliff
800-864-2470
Old 07-31-2006, 12:33 PM   #40 (permalink)
kalo's 300C's Avatar
Member Number: 5488
Thumbs up U.a.s
Zack and U.A.S are the greatest. Zack has been very helpfull in getting me with my kit and with questions about how to's. I am in process of doing my install this week, the instructions are easy to understand. If I can do it any one can. Aloha Seth.....
kalo's 300C is offline
