Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Supporting Vendors > Universal Air Suspension
Old 06-21-2007, 05:40 AM   #1 (permalink)
Points: 1,708, Level: 1 Points: 1,708, Level: 1 Points: 1,708, Level: 1
aj510's Avatar
Member Number: 11589
dakota digital controller errors...
hi,
I've got a couple of problems with my DHC-2000.
When I try to read tank pressure it displays 'EEE'
Also when I try to set a height for the 'M' button it doesn't seem to remember the height correctly, where as all other buttons are fine no matter what height I set the memory to.
Any help here would be greatly appreciated.
Modified Cars
300C Airbag Install Guide
Mods so far
22" Dvinci Havoc XL's
20% tints
Air suspension (UAS)
aj510 is offline
Old 06-21-2007, 08:11 AM   #2 (permalink)
Points: 9,242, Level: 1 Points: 9,242, Level: 1 Points: 9,242, Level: 1
LAIDBACKC's Avatar
Member Number: 1368
Any problems with the controller has always seemed to be a ground problem... go back and make sure the sensor on your tank is grounded reall well
LAIDBACKC is offline
Old 06-21-2007, 08:16 AM   #3 (permalink)
aj510's Avatar
thanks laidback - did you get that rattle sorted in your front end? If so what was it?
aj510 is offline
Old 06-22-2007, 11:29 AM   #4 (permalink)
Points: 5,286, Level: 1 Points: 5,286, Level: 1 Points: 5,286, Level: 1
Member Number: 5047
Originally Posted by aj510 View Post
hi,
If your M is too close to the L or H it may need to be set further apart.
Thats correct, it sounds like the tank sensors isn't grounded good. Make sure that you have the "2" post one in the tank and one of the posts are grounded.
-Zack Ratcliff
800-864-2470
Old 06-23-2007, 07:12 PM   #5 (permalink)
aj510's Avatar
Ahhh ok - thanks, that makes sense. I'll give that a shot today.
I checked(multimeter and test light) the ground yesterday and it is fine. The display still shows up 'EEE'.
Thanks for the help zack.
cheers,
Adam
aj510 is offline
