Go Back   Chrysler 300C & SRT8 Forum > Supporting Vendors > Universal Air Suspension
Old 01-11-2008, 01:05 PM   #1 (permalink)
UniversalAirSuspension
Member Number: 5047
Koni Adjustable Shocks
Well we have finally got some good news. Koni is receiving in our shocks next week from the factory in Holland and we should have them in 2 weeks.
Please don’t mistake these shocks from the other so called Koni shocks that were not built by the factory in Holland. These are Genuine Koni shocks designed and built by the factory in Holland. These shocks will be fully warranted by Koni with use of our air suspension systems.
We will be doing a set of mounts for all of you coil guy’s, but we won't have the brackets done for at least a month or two. As of right now they can be used with our air suspension system. Sorry AWD guys, these are only for the RWD’s.
Koni have engineered our Adjustable shock based off of their standard “sport” damper. The front’s are Adjustable though turning a knob on the shock shaft, the rears have to be removed from the car, Compressed down and turned to adjust the shock. The shocks have been shorten to allow for all of your lowering applications and not have the shocks bottom out giving a bad ride and a short life.
I personally have been testing the prototypes for the past 6 months and wow what a difference. I have ran, OEM 300, Bilstien, and an adjustable coil over and nothing can compare. There is a reason why Koni is the OEM supplier to most of your High end sports car.
Here is some information on Koni
http://www.koni-na.com/why.cfm
http://www.koni-na.com/heritage.cfm
Forum discount on the shock kit will be $800.
-Zack Ratcliff
800-864-2470
Old 02-07-2008, 09:17 PM   #2 (permalink)
SoCal-Al
Member Number: 14782
Hi Zack,
Any news on your koni adjustable shocks for the 300C ? Have they arrived ?
Thanks
SoCal-AL
SoCal-Al is offline
Old 02-08-2008, 10:43 AM   #3 (permalink)
Member Number: 5047
Originally Posted by SoCal-Al View Post
Hi Zack,
Thanks
SoCal-AL
Yes i have the struts in, however i am still waiting on the spring pearches to be finished up so that we can do your car :-)
Old 02-08-2008, 09:45 PM   #4 (permalink)
SoCal-Al
Thanks,
Let me know when you are ready with them.
SoCal AL
SoCal-Al is offline
