Old 05-31-2006, 08:06 PM   #21 (permalink)
BigC's Avatar
Car: 2006 Dodge Charger SRT-8
Member Number: 4860
Originally Posted by FreebirdSRT
Can you find out if that was the wheel alone or with tire?
I have also heard, but not confirmed, that the 300 SRT wheel weighs 3 lb less than the Magnum wheel.
OK!!
Confirmation & Verification
Originally Posted by high888
The scale was at a UPS store. The kind that sits on the floor which they use
to weigh packages and other items. I also did weigh it with my digital bathroom scale. It weighed 35lbs. as well. So, scientifically, I guess it must
weigh 35lbs., huh? My Goodyear RT-S tires weigh in addition as follows:
245/45-20 for the front - 31lbs.
255/45-20 "run flat" for the rear - 33lbs.
Sorry, but those were weighed with only the bathroom scale. So, add the
wheel weight plus the tire weight = total weight. Coming in at just a lick
under 70 lbs. per corner. You ask, "how do they feel compared to the 47lb.
factory SE tire and wheel combination"? No different. But they look a crap load better.
Clarence
General Pershing Zephyr: Named "Silver Charger" after Pershing's horse.
-Lighted SRT-8 Door Entry Guards
-Tint % 35/35/20
-K&N Drop In
-Magnaflow Catback & Catted Midpipes:
-GSM Ported Heads & Intake with Beehive Springs
-GSM ESP/Torque Management /Fan Modification & 180 T-Stat
-Quaife ATB Differential
-KW V2
BigC is offline
Old 05-31-2006, 10:04 PM   #22 (permalink)
Member Number: 232
Wow. 35lbs is a lot for a forged 20" rim.
I thought the SRT8 had forged rims which should be lighter than 35lbs. All the non-forged single piece cast 20" rims I weighed at wheel shops all weighed around 35lbs. I have forged 20" rims and they weigh 24lbs. Something doesn't seem right.
Edit to my comment above -
After further thought, some of the extra weight might be because the SRT8rims are 9" wide. My rims are 8.5" wide. Still, an extra 11lbs for an extra 1/2inch doesn't seem likely either.
joey is online now
Old 09-10-2006, 04:41 PM   #23 (permalink)
crhemi's Avatar
Car: 2006 Chrysler 300C SRT
Member Number: 3307
Bump for acurate info.
!/4 12.756 @ 110.35 mph w/ 1.961 60'
crhemi is offline
Old 09-10-2006, 04:59 PM   #24 (permalink)
FreebirdSRT's Avatar
Member Number: 4247
Trader Rating: (10)
Hey CrHemi. Soon, I am going to weigh the following wheels. Since I have 1,2 and 4. I will use those numbers to send back to USW for when they go to make a 20" forged. The goal is to make the 20" forged be lighter than the OEM SRT wheels.
1. 300SRT wheel with 245/45/20.
2. MagSRT wheel with 245/45/20.
3. ChargerSRT wheel with 245/45/20 (still waiting to hear if I can use).
4. The 22" Forged USW wheel with 265/30/22.
The last one is just so I know how much more the 22" I am running weigh against the OEM 20" SRT wheels. I want to know how much more weight I am adding to each corner with the 22" forged wheels Vs. the OEM 20" SRT wheels.
Eleanor Roosevelt, 1936
FreebirdSRT is offline
Old 09-10-2006, 05:40 PM   #25 (permalink)
crhemi's Avatar
Member Number: 3307
Thanks, I'll be watching and waiting.
crhemi is offline
Old 09-10-2006, 07:41 PM   #26 (permalink)
hemiwagn's Avatar
Member Number: 1684
I have #3; I'll weigh it this week and post it here
I did #2 in this post, it weighed 59lbs http://www.300cforums.com/forums/srt...ple-posts.html
2006 MSRT8
2006 Charger SRT8
NEW! 2005 300 Limited
1991 Chev Gettolier
hemiwagn is offline
Old 09-10-2006, 08:24 PM   #27 (permalink)
Member Number: 4247
Trader Rating: (10)
Thanks Hemiwagn . Is that 59lbs with a tire on the wheel or wheel alone? Was it a 245 or 255 /45/20?
Old 09-10-2006, 10:41 PM   #28 (permalink)
hemiwagn's Avatar
Member Number: 1684
59 lbs: that was the 245/45/20 F1 supercar tire factory installed on the stock Magnum SRT8 wheel.
2006 MSRT8
2006 Charger SRT8
1991 Chev Gettolier
hemiwagn is offline
Old 09-10-2006, 10:59 PM   #29 (permalink)
Member Number: 6743
Hello everybody. US Wheel and I are working together to try to bring you a 20" forged wheel that will still be just as strong but weigh less than the OEM SRT wheels.
I have heard from some members that the 20" 300 SRT wheel weighs less than the Magnum and Charger SRT wheels.
To ensure USW makes a light enough wheel. They would like to know the OEM weights of the 3 different SRT wheels. If someone knows the exact weight of the wheel, please let me know.
300CSRT OEM wheel weight=_______
MagnumSRT OEM wheel weight=_______
ChargerSRT OEM wheel weight=________
I also know that from reading other post's. The SRT wheels will gain 1 lb when you chrome them. Since the SRT wheel finish is already bare aluminum, there is not much weigh shaving when you strip down most wheels and chrome them.So if you chrome your SRT wheels you will be adding 1 lb to each wheel.
CSRT 8 wheel = 39 lbs with 245/45/20 Goodyear RSA tire.
VYPER883
300C...A Demon In Gentleman's Clothing....
Chrysler.... Five Star Service? Yes Please.
PentaStar Emblem From Cerebus? No Thanks, I'll Pass...
vyper883 is offline
Old 09-10-2006, 10:59 PM   #30 (permalink)
Member Number: 232
How many miles on your tires? My Conti's were about 4lbs lighter after 13.5k miles.
If the tire weight is being subtracted to arrive at the rim weight, it matters how much tire wear has occurred.
joey is online now
