Old 06-11-2006, 03:09 PM   #1 (permalink)
hemiwagn's Avatar
Member Number: 1684
New staggered tires that will fit SRT8's
The new Nitto INVO *might* do the trick. The website is a bit weak on detailed specs for the tire, but it is their new ultra high performance flagship tire. Definitely summer only and NOT for SUVs.
and get this, not all the sizes are released but the website says it will come in:
245/45/20
255/45/20
and 275/40/20 - which is the same diameter as 245/45 btw
about the website http://www.nittotire.com/tires_invo.asp
if you click on sizes and specs from above you will only see the 255/45 size. BUT
if you click on 'experience the invo' THEN click on tire sizes you will see all 3 above.
Can't wait until I wear my F1's out.
As teahead has mentioned, Toyo Proxes4 come in 245/45/20 and 275/40/20 as well. To date those are the only matched staggered tires in the with the stock front 245/45/20 size.
2006 MSRT8
2006 Charger SRT8
NEW! 2005 300 Limited
1991 Chev Gettolier
hemiwagn is offline
Old 06-11-2006, 04:53 PM   #2 (permalink)
FreebirdSRT's Avatar
Member Number: 4247
Trader Rating: (10)
If you don't want to go with the exact front tire size. I have seen on a few LX's. 275/35/20x9 F and 295/40/20x10.5 R The rear is a tight fit but no rubbing.
Eleanor Roosevelt, 1936
FreebirdSRT is offline
Old 06-11-2006, 08:49 PM   #3 (permalink)
Moose's Avatar
Car: 2006 SRT-8 6.1 Hemi 300c
Member Number: 4390
Trader Rating: (4)
Nitto's are junk, imo. I had Michelin's on my Accura and when I repalced them I was told to go to Nittos. I did and regretted every minute of it. I have not tried their new design, but the rubber they use is no where near Michelin standard.
Good luck.
Moose Burnout here
Highest trap 120 MPH
Fastest reaction time 0.00
Mod list:
Secret Moose Diablo tune
Magnaflow high flow cats
TNT dual nozzle
Corsa cat back
GSM fan mod
180 tstat
Back to Back TO BACK>>Calendar Winner
What happened to us running out of oil?
Moose is online now
Old 06-11-2006, 09:46 PM   #4 (permalink)
teahead's Avatar
Member Number: 164
I think 275 is probably the max you want to put on a 20x9 wheel.
NEXT MOD:
9" headrests, TVNav2Go
teahead is offline
Old 06-11-2006, 10:41 PM   #5 (permalink)
Member Number: 4247
Trader Rating: (10)
I concur teahead.
275 sizes and down for a 9" wide wheel. 255 sizes and down for an 8.5" wide wheel.
Old 06-12-2006, 05:47 PM   #6 (permalink)
teahead's Avatar
Member Number: 164
I wish someone would make a 295-35-20. I think 295-40-20 is just too tall looking.
NEXT MOD:
teahead is offline
Old 06-12-2006, 08:23 PM   #7 (permalink)
Member Number: 4247
Trader Rating: (10)
I hear ya teahead. I wish they did too.
Old 06-13-2006, 02:20 PM   #8 (permalink)
E55 KEV's Avatar
Member Number: 10
Good luck.
Was it a Max Performance Tire? It would be nice to know which model you had rather than generalize all tire models. Not even over priced Michelin makes a superior tire in every model they make. I run NT555 on the rear of my E55 and they stick good with all forward motion and traction. E55 has a hard time breaking them loose or making them squeal.
E55 KEV is offline
