Old 08-03-2006, 07:47 PM   #1 (permalink)
Points: 2,813, Level: 1 Points: 2,813, Level: 1 Points: 2,813, Level: 1
Car: 2006 Dodge Magnum SRT8
Member Number: 3495
NEW TIRES! PROXES 4 in a 275/40/20
Just wanted to share with everyone here the info that you can get the Toyo Proxes 4 in a 275/40/20 for the SRT8. This is the size that DCX should have put on our cars in the first place. At 33000km, my RSAs were toast and it was time for new rubber. This is the perfect upsize as the tire diameter is almost exactly the same as stock. Initial feedback is that it is a great tire, lots of additional grip in the braking and handling department. A little louder at highway speeds, but I am being fussy here... The great thing is that I paid $798.00 out the door and on the road for these meats. Everyone that has seen them has commented that they look awesome as well. Bought em from Belle Tire in Novi, Mi. If you guys/gals are looking for new rubber, look into these tires. They are a steal for this size! Before I pulled into the tire shop, I annihilated the stock tires with several burnouts and powerslides in an empty parking lot. A couple clips of the fun for those interested...
http://videos.streetfire.net/video/f...120143787d.htm
http://videos.streetfire.net/video/b...12014f4fed.htm
Later,Tomi
black srt8 is offline
Old 08-04-2006, 11:37 AM   #2 (permalink)
Points: 2,738, Level: 1 Points: 2,738, Level: 1 Points: 2,738, Level: 1
Ben Dover's Avatar
Car: 2005 Chrysler 300LTD
Member Number: 5651
The Toyo Proxes 4 has been available in that size for a while now.
I just got mine in 255/35R22 from www.tententires.com
Also available in 275/40R20 is the following:
Yokohama ADVAN S.T.
Toyo Proxes S.T.
Pirelli P-Zero Rosso
Michelin Latitude HP
Michelin 4x4 Diamaris
Kumho Ecsta STX
Hankook Ventus RH06
Continental 4x4 SportContact
Ben Dover is offline
Old 08-07-2006, 02:23 AM   #3 (permalink)
Points: 3,637, Level: 1 Points: 3,637, Level: 1 Points: 3,637, Level: 1
Midnightsun300c's Avatar
Car: 2006 Chrysler 300c AWD
Member Number: 6238
A great second video from ground level!..inventive and very entertaining. I have had Yokohama Parada Spec Xs in a 275/45/20 on my AWD and just upgraded to the Y rated Pirelli P Zero Rosso in the 275/40/20 and I concur...the 275/40/20 looks good on the C. I get the feeling that I will never need the esp feature with 275s...I don't think they will ever break loose unless I want them to. I am just a touch surprised that you went with a W rather that a Y for your 6.1. I figured when the aftermarket cracks the code on the 6.1 you will be able to do mid 180s routinely.
275/40/20 Pirelli P Zero Rosso tires; Detata Double D 20x9 chrome wheels; KW VII coilovers; Dynatech LT Headers; CORSA Exhaust; 180 Tstat; DR Heads; FRI Littleboy Cam; 6.1 forged crank & dampener; RR forged 8.6:1 pistons; forged rods; A Pillar PSI & AFR meter; Bullet twin screw w/ intercooler; 15 psi w/ 90 octane; Methanol Injection; Predator; Tuned by Underground Performance.
Midnightsun300c is offline
