Old 02-01-2005, 08:48 PM   #1 (permalink)
LAIDBACKC
LAIDBACKC's Avatar
Member Number: 1368
ANYONE WHO KNOWS WHAT SIZES I NEED FOR NO RUBBING ON 22's
I wanna obviously buy 22's, I jus dont want any rubbing and im not an expert on what all the tire sizes mean and offsets..... Also I notcied that bolt above the front tires.....
1) If i plan on lowering the car how will that effect that bold
2) do i need to consider different tires if im going to lower it?
and also wut do u think of lexani krystals..... i had lexani krystals on my montero sport, do u think they would match this car in 22's well.... I think lexani the name and the look are both classy...
http://www.lexaniwheel.com/Pages/MasterFrame.html
LAIDBACKC is offline
Old 02-01-2005, 08:52 PM   #2 (permalink)
tommyz
tommyz's Avatar
Member Number: 962
Trader Rating: (6)
youll need 265/35/22 tires... from either nitto or pirelli ...
tommyz is offline
Old 02-01-2005, 11:04 PM   #3 (permalink)
LAIDBACKC
LAIDBACKC's Avatar
Member Number: 1368
IS IT POTTIBLE TO HAVE 22's and LOWERED and NOT RUB AT ALL
Old 02-02-2005, 03:39 PM   #4 (permalink)
LAIDBACKC
LAIDBACKC's Avatar
Member Number: 1368
when i lower it after i put the 22's on, how does it effect that bolt above the tire...?
Old 02-02-2005, 04:01 PM   #5 (permalink)
300Con23s
300Con23s's Avatar
Car: 2005 Chyrsler 300C
Member Number: 461
I have mine lowered with 22's and the Pirelli tires. Check out -> My 300C with 22" TIS and Eibach's
300Con23s is offline
Old 02-05-2005, 08:42 AM   #6 (permalink)
503 motoring
503 motoring's Avatar
Member Number: 1094
Mine is lowered with 22x10 in the rear and 22x8.5 in the front and a 15mm offset. There is no rubbibg at all and the turn to turn does not touch the inner wheel wells. Plus dont worry about the bolt. As long as you are running the 265/35z22 then it will sit just below the bolt and the bolt moves with the tire so it will never touch.
06 Silver Steel C with customized STRUT Detroit package, Customized STRUT Side Vents, Eibach springs, Suede Headliner, 3M Paint Protection Film, 50% Suntek Film.
503 motoring is offline
Old 02-05-2005, 10:50 AM   #7 (permalink)
aspendog
aspendog's Avatar
Member Number: 69
Trader Rating: (14)
I am running 22x9.5 +15 offset with 285/30/22 Dunlop 9000. I finally got rid of the rub I had when in reverse at certain angles with full turn. I grinded the arm about 2-3mm and now there is no rubbing. I like having the wider tires personally but you would have to make sure you had a 15 or less offset, if it was 18 or more it would not work...
aspendog is offline
Old 02-07-2005, 02:56 PM   #8 (permalink)
TANAHARA_DESIGN
TANAHARA_DESIGN's Avatar
Member Number: 1449
22's and no rubbing
I am running Michelin Pilot sports
295/22/30 series in the rear
255/22/35 series in the front
My car is lowered and there is no rubbing.
Tires are going for about 1100.oo each.
hope that helps
TANAHARA_DESIGN is offline
