I wanted to ask if anyone would happen to know what my vibration problem is. Its kinda a long and confusing story so I will try my best to keep it simple.
About 3 weeks ago, me and the family traveled about 900 miles one way. At this time I had the stock wheels and tires. Which were the contis. I had a vibration which started at around 60mph and up. And it lasted the whole 900 miles to our destination. It was horrible. I was blaming the contis.
So at our destination, which was in Kentucky to see family and friends, I decided to do some mods. I got Hotchkis sway bars installed, Gibson Exhaust installed, custom pin striping, and 20" Martin Brothers Sharktooth wheels with Hankook Ventus tires 275-40-20. I got all of this done in about 2 days. I jumped onto the freeway and the vibration is still there. its not any worse or any better. So I called the guy that put on the wheels and tires and told him about it. I took it back in and he re-balanced them. Even road forced balanced. The wheels are 5x115 bolt pattern and he also put Hub Centric Rings on too. I then went and had an alignment done as well.
I still have the vibration about 60mph+ and I am also back at home. I dont have a clue as to what could be causing this problem. I have had the tires and wheels now balanced 3 times at 2 different places.
Anyone have any suggestions?
sorry this story was so long and thanks in advance for your help.
2006 300C Silver Steel
De-Molded & De-Badged
K & N Cold Air Intake
Hotchkis Sway bars
Gibson Dual True X Exhaust
Rear Deck Lid Spoiler
Custom Pin Stripping
20" x 9" Martin Brother Sharktooth Wheels
Hankook Ventus ST 275-40-20
Vip300C SRT Front Lip
Stealth Pedals
08 Dodge Charger SRT8 Super Bee
MagnaFlow Cat-Back Exhaust
I would take the car to the dealer. It sounds like you might have a suspension problem. You could also try jacking up the front end and try wiggling the wheel to see if there is any play. If there is, I think you may have bad tie rods.
Here is some info from the service manual, under the Tires/Wheels section.
ROAD TEST
Road test vehicle on a smooth road for a least five miles to warm tires (remove any flat spots). Lightly place hands on steering wheel at the 10:00 and 2:00 positions while slowly sweeping up and down from 90 to 110 km/h (55 to 70 mph) where legal speed limits allow.
Observe the steering wheel for:
² Visual Nibble (oscillation: clockwise/counterclockwise, usually due to tire imbalance)
² Visual Buzziness (high frequency, rapid vibration up and down)
To rule out vibrations due to brakes or powertrain:
² Lightly apply brakes at speed; if vibration occurs or is enhanced, vibration is likely due to causes other than
tire and wheel assemblies.
² Shift transmission into neutral while vibration is occurring; if vibration is eliminated, vibration is likely due to
causes other than tire and wheel assemblies.
For brake vibrations, (Refer to 5 - BRAKES - BASE/HYDRAULIC/MECHANICAL/ROTOR - DIAGNOSIS AND TESTING).
For powertrain vibrations, (Refer to 3 - DIFFERENTIAL & DRIVELINE - DIAGNOSIS AND TESTING).
For tire and wheel assembly vibrations, continue with this diagnosis and testing procedure.
Are your lug bolt clips still on?? I believe they're called Tinnerman clips. There's two on each corner of the car. I just took mine off today and my vibrations at high speeds has been reduced, but I still have a little since I'm not running hub centric rings yet.
__________________ Mods:
35% Tint
Debadged
Demolded
22" Devino Staminas with Hankook 265/35/22 tires
6000K HID
Chrome Mesh Grill
"BLACKOUT" Vanity Plate
Eibach Pro-Kit
Halo headlights
Chrome bulbs
Color matched pillars
Color matched bumper inserts
Color matched medium tinted taillights by Jons Tinted Tails
Color matched medium tinted side markers by Jons Tinted Tails
i seem to have a similar problem...
the problem didn't exist when i had on stock rims and tires, but i recently upgraded to 22's (9.5'' front, 10.5'' rear) and it feels like the car starts to "dance" around the road at speeds of 85mph+ it gets really annonying, like its bouncing on the front tires just a little to the left and the right.
anyone have a clue?
and i did watch the tires get put on and the guy did remove those little rings
anyone have a clue?
You probably need hub centric rings like I do.
35% Tint
Debadged
Demolded
6000K HID
Chrome Mesh Grill
Eibach Pro-Kit
Halo headlights
Chrome bulbs
I Have 20s On My Car And Have The Same Problem When I Hit 65 Mph And Stops When I Go Faster.it Happend When I Rotated My Wheels.i Brought The Car Back To The Tire Shop And They Told Me One Of My Tires Have A Just A Little Hump In It. They Just Took Off Some Of The Weights They Put On To Balance The Tires.i Know You Just Bought New Tires So I Know You Wouldnt Have The Hump I Had But Maybe There Is A Problem With The Weights On One Of The Rims.because After They Removed Some Of The Weights The Car Rides So Much Better.good Luck
