Old 05-02-2007, 04:02 PM   #1 (permalink)
Car: 2007 chrysler 300c
Member Number: 11991
10mm offset ok?
Found great set of wheels. 10mm offset is a bit of a concern..mfg says ok but chrysler says 15-20 offset is correct for rwd 300. any experience with this?
OK.. 2 YES..2 NO..ANY TIE BEAKERS?????
rapadu is offline
Old 05-02-2007, 05:11 PM   #2 (permalink)
Topmotorsports's Avatar
Car: 07 Dodge Charger
Member Number: 4754
Send a message via Yahoo to Topmotorsports
What width?
For those who like to ride on TOP!
Topmotorsports is offline
Old 05-02-2007, 05:36 PM   #3 (permalink)
8.5" 240-40-20 tire
rapadu is offline
Old 05-02-2007, 08:07 PM   #4 (permalink)
Member Number: 4754
that will be fine.
Old 05-02-2007, 08:39 PM   #5 (permalink)
Member Number: 232
Something doesn't look right. You sure it isn' 245-40-20, instead of 240-40? None the tire calculators have a 240-40.
The best tire fit for our cars is 275-40-20, next 245-45-20, then 255-45-20.
Offset 10 doesn't look right either. It may fit without rubbing, but your wheels are going to be sticking way out beyond the edge of the fenders.
I personally would avoid an offset 10.
joey is offline
Old 05-03-2007, 04:43 AM   #6 (permalink)
Member Number: 4754
Good find on the 245/40. I didn't catch that. The offset will be fine though. No problem whatsoever. It will not stick out past fender.
Old 05-03-2007, 05:12 AM   #7 (permalink)
Mack300's Avatar
Car: `06 C Chrysler 300
Member Number: 3053
I personally would avoid an offset 10.[/quote]
I think Joey has a good point.
Mack300 is offline
Old 05-03-2007, 06:07 AM   #8 (permalink)
Member Number: 4754
Why do you guys think that a 8.5" wide wheel with a 10mm offset would stick out past the fender?
Old 05-03-2007, 07:50 AM   #9 (permalink)
rapadu is offline
Old 05-03-2007, 07:51 AM   #10 (permalink)
if my math is correct it works out to be about 1/5 of an inch out. is my math correct?
rapadu is offline
