Originally Posted by 300cWannaB
i believe (someone correct me if im wrong  )that the higher +offset(18mm) would bring the wheel closer inside the wheel well, while the lower+offset(+15mm) would bring it out (stick out). If your going to run a 22x9.5" rim, then your correct offset would be +18mm...
hope that helps..
You are correct, the higher the offset the closer in the wheel will sit, but I run +15 and have no issues (I actuall have to because I run 285/30/22 tires and still had to modify a bit).
