Old 03-16-2006, 05:05 PM   #11 (permalink)
Member Number: 5047
Does anybody know why it actually only happens in reverse instead of going forward also?
-Zack Ratcliff
800-864-2470
Old 03-16-2006, 05:54 PM   #12 (permalink)
doodie300c's Avatar
Car: 2005 Chrysler 300c
Member Number: 1713
i have the tis style 02 22" with the pierelli tires. the only rubbin i get is when i go in reverse and turn the wheel completely, besides that i dont have a problem with the rims and tires. the tires are real close to the control arm, i diddnt do anything left them like that, one side is closer to the control arm then the other. ride is good just alil ruff when u hit bumps and potholes.
ty
D
doodie300c is offline
Old 03-16-2006, 06:36 PM   #13 (permalink)
GEN XER's Avatar
Member Number: 600
Trader Rating: (6)
Originally Posted by aspendog
D'Vinci Havoc XL (custom painted)
22x9.5" +15 offset w/ 285/30/22 Dunlop 9000
Aspen, are your side markers light or med tint? I assume you got them from Avon?
DARKSIDE - 31OCT06:
GREY GHOST
Resonator Delete
Mopar CAI/ K&N RF 1029 Filter
Posi Quiet Brake Pads
Slotted Rotors (TSB)
Lowered Front Lic Plate
Smoked Red LED's
Oil Filter Magnet
Motorad 180 T-Stat
Coolit Fan Mod
Quantum Blue Oil
Quantum Blue Coolant
ACES IV Fuel Improver
GEN XER is offline
Old 03-16-2006, 08:58 PM   #14 (permalink)
300@Vancouver
Member Number:
Posts: n/a
Just run the 3mm spacer. It will be fine, and if you are running Hub centric it will reamin that way...anything thicker then you won't be hub centric because it will be floating. So the spacers are fine to use.
Originally Posted by 23NCRUZINAHEMI_C
what do you think would be better? spacer(only 3mm) or shave and repaint control arm?
Old 03-16-2006, 09:15 PM   #15 (permalink)
whatsurdream's Avatar
Car: 2006 charger r/t dodge
Member Number: 4278
If the spacers made the wheels flush to the fender I would run it. Otherwise I would grind the arm and call it a day.
whatsurdream is offline
Old 03-22-2006, 05:53 PM   #16 (permalink)
GEN XER's Avatar
Member Number: 600
Trader Rating: (6)
What he said.
GEN XER is offline
Old 03-22-2006, 08:41 PM   #17 (permalink)
Member Number: 4803
hey man i have the same setup on my 06 300c and the shop where i got my rims/and tires just grinded the back a little and its fine no problems here. just my 2 cents
ericl815 is offline
Old 03-24-2006, 03:09 PM   #18 (permalink)
Member Number: 5047
Does anyone know why it only does it when in reverse? does it have to do with the caster? or what?
