Originally Posted by Sunney
Not really its a bit taller but nothing to worry about. The diameter difference is only 1.45%. Its when you get past 3 when its a problem. Lots of people have done it, no rubbing either.
To me its more than just the increase diameter....which throws off the speedo, mileage figures of the onboard computer...its the additional weight of the larger tires. You're adding quite a bit of rotational weight to each wheel which effects you're acceleration.
Overall a bad move. If you want a larger footprint, stick with a like diameter tire to the OEM 225/60...which would be a 245/55.
If you want some additional performance than go with the slightly smaller diameter 235/55, which is standard on the Daytona Charger model. That will give you a lighter tire which also has a stiffer sidewall which should give additional handling response and a little quicker acceleration. You will also get a slighly firmer ride with the shorter sidewall however.
