def not worth keeping them on if your area has salt. salt plus chrome dosent mix.
on top of that im assuming that you have summer tires on your 22s. Summers and cold weather dont mix well either. Summer tires are a harder compund that will jsut freeze once temps get near freezing. Winter tires are a much softer compound that will remain usable even at sub zero temps.
Like he said. Once salt pits your chrome, no amount of cleaning will make them shine again. Not worth the risk. I wont put my chromes back on until after a couple of good rain falls in the spring to rinse the roads.
The chrome won't be bothered by the salt...it's that the snow/ice performance of a large lo-pro wheel and tire will be CRAP. You need sidewalls to help move you along in deep snow.
Chroming was originally developed as a plating to increase the durability of otherwise very delicate finishes (steel, aluminum, etc) because chrome doesn't rust, and is VERY hard, so being exposed to the elements isn't the problem. They're harder to keep looking clean, so that's probally what most people's problem with them in the winter is. I have the stock chrome 18"s on my car, and while they don't look the best, there's no trouble with them rusting or pitting or anything. Polished aluminum though, you'd better watch out.
I beg to differ. It is largely dependent on the quality of the chroming job and alot of these wheels are made cheaply offshore.
No one said they would rust but they do corrode, you know that white powerdery crap. I use my factory wheels, chrome, every winter and they look like crap, corroded everywhere from the salt. The plastic center is ok but the chrome plated aluminum edge is now corroded garbage. My chrome wheels that I take off for the winter and never see salt shine like mirrors and only require a light dusting once in a while. Chrome doesnt rust but it will corrode when it comes into contact with salt and it is not cleaned off.
I wonder if you've got the problem detailed here - Wheels Pitting - Have You Checked Yours. Seems like a lot of the early OEM wheels had a defect that made the problem much worse, at least.
i live in michigan and keep them on all year they really suck in the winter thoe you dont move very well but i go back and forth to missouri every week so i dont feel like switching them all the time so i say f it and run them i have had to replace 2 rims this year due to potholes but o well need to look good
and there is a price to pay for that
