Old 07-09-2008, 06:12 PM   #1 (permalink)
Member Number: 7448
srt wheels on a 300C
So, i mounted a set of srt wheels on my 300 c and they look great. Two problems. First my tpms is going off all of the time. I plan to put snow tires on the stock wheels and use them in the winter so I don't want to remove them from the original wheels. Can I disable the system? And second the front wheels rub in reverse (only). I can turn the wheels lock to lock going forward and no rubbing but with not much turning going in reverse I can hear them. Any suggestion? Thanks!
Club186 is offline
Old 07-09-2008, 06:15 PM   #2 (permalink)
4life's Avatar
Member Number: 12657
Is it the wheels rubbing in the front or just the wheel weights. I havent put those wheels on myself but a guy I ran into on the streets did it without spacers. He mentioned he had no rubbing but he had to move the wheel weights or they would rub.
4life is offline
Old 07-09-2008, 06:29 PM   #3 (permalink)
smoove7410's Avatar
Car: 2006 Chrysler 300c
Member Number: 50
If these are oem srt8 wheels, you will need spacers on the front to run them on your C.
smoove7410 is offline
Old 07-09-2008, 06:45 PM   #4 (permalink)
fireman144's Avatar
Member Number: 10167
bones enterprizes out of Ga, I purchased thier spacer and it fixed the problem with the SRT8 wheels on my 300c
fireman144 is offline
Old 07-09-2008, 07:26 PM   #5 (permalink)
Keithyhome's Avatar
Member Number: 12382
you need the small (3mm) spacers. They look big (thick) enough to make a difference but they do.
I run the SRT replicas without any rubbing at all.
2006 300C Bright Silver (PS2)
Mods include:
HHP High Flow Cats
Diablo Predator 91CAI tune
180 Thermostat
Borla Cat-back #140112
GS Motorsports Fan/ESP torque switch
C&L intake
Demon-eye Halo kit (ACCStyle.com)
U-connect bluetooth
Mopar lowering springs
20 inch SRT8 replica wheels
http://home.earthlink.net/~keithyhome/
Pending:
Long Tubes
Comp XFI 268 cam (already purchased)
Keithyhome is offline
Old 07-09-2008, 07:28 PM   #6 (permalink)
Keithyhome's Avatar
P.S. I have an extra setup of spacers if you can not find them locally. Will mail to you from Florida.
Old 07-24-2008, 12:35 PM   #7 (permalink)
07BLKLTD's Avatar
Car: 2007 Chrysler 300 Limited
Member Number: 18595
do you still have those spacers?? im interested if you do!!
2007 Chrysler 300 Limited Black/Khaki Int: VentureShield Clearbra, SRT-8's, 35% Tint, Stull Grill, Stealth Bulbs thru-out, Clear Side Markers, iPod integration
2007 Lexus GS350 Glacier Frost Mica/Blk Int: Mark Levinson Sound, VentureShield Clearbra, 50% Tint (including Windshield), Tein CST Coilovers, iPod integration, Nokya 2500 Fogs, PIAA Ion Crystal Markers
07BLKLTD is offline
Old 08-01-2008, 02:58 AM   #8 (permalink)
Car: 300c chrysler 2006
Member Number: 17929
I had the exact same problem as you do with the rubbing. I had to use spacers.
ItalianBostonian is offline
Old 08-01-2008, 09:56 AM   #9 (permalink)
Car: 2007 chrysler 300
Member Number: 16001
Do the srt-8 wheels fit on the basic chrysler 300. I upraded to the 18's and now found a good price on a set of srt-8's. I think i will need the spacers, but will they fit and not rub
gaibave2 is offline
Old 08-03-2008, 03:44 AM   #10 (permalink)
You will prob need spacers.
