Old 09-29-2009, 08:19 PM   #1 (permalink)
Points: 43, Level: 1 Points: 43, Level: 1 Points: 43, Level: 1
Car: 2009 Chrysler 300 Touring
Member Number: 23998
Send a message via Yahoo to Bobby Light
Will 22's fit
Alright i know 22's will fit on the car itself but will the tire rub on the steering control right above the rim or what. do you have to do anything to modify this or are u set to go with nothin to change??
Bobby Light is offline
Old 09-29-2009, 10:00 PM   #2 (permalink)
Points: 1,955, Level: 1 Points: 1,955, Level: 1 Points: 1,955, Level: 1
Car: 2008 Chrysler 300C
Member Number: 20491
Trader Rating: (4)
You will probably need to grind the control arm bolt down to clear the tire. Depending on tire size (25, 30 or 35 series) will determine how much grinding is involved.
Mopar/K&N CAI, Stealth bulbs and color matched side markers, removed moldings and badges, 20%Tint, VIP300 Mad Eye Lids, 24" Velocity 800s with 265 30 R24 Kumho Ecstas, Grip chrome grill, Mygig Nav and VES
Patrick M is offline
Old 09-29-2009, 10:09 PM   #3 (permalink)
Points: 17,707, Level: 1 Points: 17,707, Level: 1 Points: 17,707, Level: 1
Activity: 38% Activity: 38% Activity: 38%
CUEBALL's Avatar
Member Number: 3447
If you have the correct offset and no more than a 255 width on the front.... no problems. Most 265 widths on the front have no problem, but there are some tire brands that have a wider shoulder that can rub the control arm.
Most have zero issues, just choose the correct wheel fitment....
CUEBALL is offline
Old 09-30-2009, 12:05 AM   #4 (permalink)
Points: 2,347, Level: 1 Points: 2,347, Level: 1 Points: 2,347, Level: 1
Concrete's Avatar
Car: : : :
Member Number: 21143
What 22's are you looking into? Are they 1 piece or 3 piece?
Concrete is offline
Old 09-30-2009, 07:34 AM   #5 (permalink)
They are one piece american racing RT-S
Old 09-30-2009, 07:41 AM   #6 (permalink)
Points: 6,799, Level: 1 Points: 6,799, Level: 1 Points: 6,799, Level: 1
lethal300c's Avatar
Car: 2007 Fiat 300C
Member Number: 18258
Trader Rating: (9)
I run 22x265x35 on my front with no issues. I did however need to buy the 3MM spacers. Did not rub on the control arm bolt at all (not that there is a lot of clearance). I suspect if I had gone to anything above the 35 aspect ratio, it might have rubbed.
Keith
PPP Stage III Heads/Cam * K&N CAI * ARH Long Tubes w/High Flows * Borla 125 Aggressive Exhaust w/5" Tips * DMH Low Profile Cutouts * DiabloSport w/CMR Tune * Zex Nitrous * PI 3600 TC * 1,000+ HP Tranny Upgrade * Black LED Tails * TIS03 22" Wheels * And many more
You will be sorely missed Mr. iNCREDIBLE! Thanks for everything you have given to this group. I'll see you on LXF.
lethal300c is offline
Old 09-30-2009, 08:16 AM   #7 (permalink)
Points: 19, Level: 1 Points: 19, Level: 1 Points: 19, Level: 1
crissylee's Avatar
Car: 2006 Chrysler Sebring
Member Number: 23984
yeah, its all about the right offset- just make sure its all good and you shouldnt have to do much else.
-a
You aint gotta downgrade, you can get what i get-T.I.
crissylee is offline
Old 09-30-2009, 09:38 AM   #8 (permalink)
Points: 1,184, Level: 1 Points: 1,184, Level: 1 Points: 1,184, Level: 1
Car: 2005 Chrysler 300
Member Number: 21077
Just an FYI the goodyear eagle's have a large rim protector that will get reaaal close or rub the side of the knuckle.
lowryder99 is offline
