I installed Tire Pressure Sensors and a 300M EVIC in my '01 Intrepid R/T without any problems. Matter of fact, I also took them off when I purchased a set of 18' wheels for it. I used a copious dosage of Dawn dish soap and they slid out fairly easy.
As for the following:
Originally Posted by HEMI4ME?
I heard from another retailer that if you do take them out of the stock wheels and try to install them in the new ones that you could have a leak due to the sensors O ring which could become damaged during the re install... Furthermore they said the leak could be one not noticed immediately, and could have weeks or months down the road.
There were no leaks whatsoever when I swapped them over. How am I so sure......the EVIC system on the 300Ms gave a digitial readout out of each tire to include the spare and the pressure was right on the button with what I put in each tire (a feature I wish was available on my 300C.....maybe a flash update is in the works at DCM). I guess if the area where the sensor seals through the stem opening on the wheel tears, one may have a leakage issue. There is lengthy discussions on this subject at
Dodge Intrepid Forums. Do a search on it.
Hope this helps.....cheers
