Old 07-22-2005, 09:54 AM   #1 (permalink)
Member Number: 2909
Tires rotated every 6000 miles?
Has everyone been told by their dealer that the 300C tires need to be rotated every 6,000 miles? We were just told that by our dealer and our car has 15,000.
We took it in because the front end was viabrating at 65-70 mph. Thought it needed alignment. But it's the worn tires which they are only rotating and balancing at this point (our expense).
Trenton is offline
Old 07-22-2005, 10:13 AM   #2 (permalink)
Member Number: 965
[quote=Trenton]Has everyone been told by their dealer that the 300C tires need to be rotated every 6,000 miles?QUOTE]Your owner's manual specifies 6K rotations on both the "A" & "B" maintenance schedules.
frank29 is offline
Old 07-22-2005, 10:35 AM   #3 (permalink)
LWOOD's Avatar
Member Number: 166
Send a message via Yahoo to LWOOD
Check out this thread
Here
And this one http://www.300cforums.com/forums/arc...hp/t-4368.html
And still more about tires
LWOOD is offline
Old 07-22-2005, 11:08 AM   #4 (permalink)
Car: 2005 Black 300c
Member Number: 130
Based on personal experience, if you want to maximize the tire life you should rotate as documented. Also, reduce the air pressure in the rear tires a few lbs below manufacture's recommendations.
Below is a link with some pictures of the tire wear if you don't rotate.
Front Tire Wear - Caused by Alignment Issue
Clearly, the front alignment has some issues when shipped on early 300c's back in May 2004. Also you can see the manufacturer's tire pressure caused the rear tires to wear excessively in the centre. I specifically asked the dealer not to rotate the tires due to my personal preference for balance of the tires. The original balancing from the factory is always best.
Downside, by rotating the tires you mask the root issues with the car's tire wear problems.
300c Owner is offline
Old 07-23-2005, 10:36 PM   #5 (permalink)
mspeasl's Avatar
Member Number: 320
Gang,
After almost 21K the tires on our "C" are about to the wear bars and I'm 63 years old. The "Connies" are a "POS" and they will not do anything for you. I called the OEM and they more or less told me "Tough". To say that I am not a happy camper is an understatement!!!.................... As soon as someone else makes tires for this car, they will get my business.
Mspeasl
05 300 'C' Satin Jade Pearl
Delivered June 1, 2004
Delivered August 29, 2002
mspeasl is offline
Old 07-24-2005, 12:06 AM   #6 (permalink)
II kings 9:20's Avatar
Car: 2005 Hemi 300C
Member Number: 132
Originally Posted by mspeasl
Gang,
So I guess the BFG KDW and P6 are not quite adequate? I am in the same boat, just got back from Cleveland and the car has such a poor ride of rough pavement. My wear is OK, but the steering wheel dances on the bumps and the rear steps out on bumps in curves and the body flicks left or right on bumps when going straight. I wonder (hope and pray) if this is all tire, otherwise the suspension is poor, no way this thing keeps up with a Mustang on the track, you'll be too busy fighting the wheel and unstable rear end. I am going to make a move on tires within 10 days.
II kings 9:20 is offline
Old 07-27-2005, 08:42 PM   #7 (permalink)
Member Number: 2964
Have a quick question ? I have 6000km on my 300C AWD and have had my conti tires balanced THREE TIMES these last two weeks. Now i am experiencing shudder from my steering wheel especially at about 55 mph : it lessons at higher speeds but i notice a vibration ( not serious ) coming from the front tires regardless of what speed i go !
Can someone please advise me what exactly is happening ? And please advise what to do ?
Thank You
B D HEMI
B D HEMI is offline
Old 07-27-2005, 08:51 PM   #8 (permalink)
Member Number: 2964
I just wanted to mention that my alignment was performed two weeks ago and the tread wear looks ok . Somebody had suggested to raise my tire pressure to 40 PSI but the rides like an dump truck !, so i lowered it to exactly : 30.5 PSi all the way around.
Cheers
B D HEMI
B D HEMI is offline
Old 07-27-2005, 09:00 PM   #9 (permalink)
Car: 2005 Hemi 300C
Member Number: 132
The Contis are so bad I am trying to wear them out, no rotations for me.
Old 07-28-2005, 07:34 AM   #10 (permalink)
rbb2000's Avatar
Car: 2006 C AWD 300
Member Number: 2617
Thank You
B D HEMI
Got exactly the same car and the same problem. I only got 2300 miles. Check out this thread. i have an appointment to go in to the dealer tomorrow but am questioning whether to go or not now. I don't want them to make it worst. check out this thread
Steering Wheel Vibration 60-70 mph
rbb2000 is offline
