Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Supporting Vendors > Zeckhausen Racing
Old 04-10-2009, 10:13 PM   #1 (permalink)
Points: 3,041, Level: 1 Points: 3,041, Level: 1 Points: 3,041, Level: 1
qmchugh's Avatar
Car: 2006 Chrysler 300C Srt-8
Member Number: 16212
Posi-quiet pads - my $.02
Installed them about 2 weeks ago and love them.
A little extra pedal effort on the first stop or two... when they're cold. However, when they warm up... to normal driving temp... they're incredible. Low pedal effort... not grabby... and as the name says... quiet. I have yet to hear a squeal.
I broke them in (even though they're scorched and probably didn't need it) in accordance to Dave Z's break-in write up and they've been making me smile since.
If you've been using napa/kragen/o'reilly/worldwide pads... make the upgrade to Zeckhausen's posi quiet and break them in as per his instructions. You'll be glad you did
SRT-8
Blacked out staggered Viper reps
Red caliper swap
Hotchkis sways front & rear
Air Suspension
slotted rotors & posi-quiets
AFE stage 2, Predator tune
SLP cat-back
Demoulded/debadged
Rear diffuser
1500 watts & a W7 in the trunk
Deep dish grille
qmchugh is offline
Old 04-11-2009, 01:55 PM   #2 (permalink)
Points: 9,141, Level: 1 Points: 9,141, Level: 1 Points: 9,141, Level: 1
DZeckhausen's Avatar
Member Number: 1056
Trader Rating: (9)
Scorching helps eliminate "green" fade by burning off the adhesives and binders that are used in the manufacturing of the pads. This eliminates most of the outgassing that occurs on initial use and makes them much less scary than many other aftermarket pads during initial heavy use.
However, another purpose of the bedding process is to deposit a layer of pad material onto the rotors. This layer introduces an additional friction mechanism known as "adherent" friction. The result is better performance. Obviously scorching of the pads during manufacturing won't put a layer of pad material onto your rotors, so the bedding process should be followed anyway.
The "no break-in" labeling on the Centric box is admittedly a bit confusing, since it's referring to the pads and not the rotors.
Below is a photograph of one of Centric's scorching machines. To give you a sense of scale, the machine is as tall as a person (not including the stacks). It sounds like a jet engine when it's running and it consumes LOTS of fuel!
Dave Zeckhausen
Owner, Zeckhausen Racing
Mopar Exhaust (older "classic" design)
DZeckhausen is offline
