2018 - 300 Limited - Squeaking in the trunk - Chrysler 300C Forum: 300C & SRT8 Forums
 2Likes
  • 1 Post By zjm8
  • 1 Post By tarheelcracker
post #1 of 7 (permalink) Old 05-13-2019, 09:07 AM Thread Starter
Points: 7, Level: 1 Points: 7, Level: 1 Points: 7, Level: 1
I'm getting a squeaking noise while driving. It varies off and on but is more noticeable at higher speeds. Trying to pinpoint the noise but have been unsuccessful. Removed the spare and replaced. Still squeaking. Any suggestions.
Thanks.
itspat is offline
post #2 of 7 (permalink) Old 05-13-2019, 09:51 AM
Points: 23,295, Level: 1 Points: 23,295, Level: 1 Points: 23,295, Level: 1
Car: 2018 Chrysler 300S AWD
Thanks.
Does it sound like a bird chirping? Has the rear of the car ever been in an accident?
zjm8 is offline
post #3 of 7 (permalink) Old 05-13-2019, 10:20 AM Thread Starter
Yes. It sounds like a bird chirping. Bought it used with 11,000 miles. No accidents reported via Car Fax.
itspat is offline
post #4 of 7 (permalink) Old 05-13-2019, 10:49 AM
Points: 4,564, Level: 1 Points: 4,564, Level: 1 Points: 4,564, Level: 1
Car: 2012 Chrysler 300C
Lube he weather stripping - see if that helps.
tarheelcracker is offline
post #5 of 7 (permalink) Old 05-14-2019, 09:42 AM
I had the same thing happen with mine. It started after I was rear ended. Here are some things to check;
Missing or loose fasteners. There are a bunch of fastener points that secure the rear bumper cover. Check the plastic fasteners in the wheel wells. There are 2 smaller screws on the bottom of the bumper cover near the wheel well. There are 2 nut fasteners under the center of the bumper cover that spin onto threaded posts that are on the bottom of the gas tank. There are 2 larger screws, 1 on each side; that are behind the wheel well insert.
I actually changed all of the above, and while it fixed the issue 90% of the time, there was still times I could hear the squeak. At that point, I decided to remove the rear bumper cover assembly. Turns out that the body shop didn't put my car back together correctly. There are teeth on the rear center of that snap in to a bracket that is right below the trunk opening. A couple teeth were not properly inserted on the right-hand side. Ironically enough, this causes a slight gap in rear quarter panel and bumper cover. I just attributed it to the car being hit and that it would never be the same. Once I put everything back together correctly, the gap was gone on the right side and I have yet to hear the noise since.
TheKrell likes this.
zjm8 is offline
post #6 of 7 (permalink) Old 05-14-2019, 01:34 PM
Do you have pass through seats? Are they secure. Have you listened for the noise with the seats down?
The Following User Says Thank You to tarheelcracker For This Useful Post:
jeffjob (Today)
post #7 of 7 (permalink) Old Today, 09:54 AM
Points: 3,613, Level: 1 Points: 3,613, Level: 1 Points: 3,613, Level: 1
Car: 2013 Chrysler 300S
This is where the squeaks occur on my 2013 300 S.
jeffjob is offline
2006 300 SRT8 Limited Edition qdwoody New Member Introductions 18 09-20-2018 02:29 PM
Audio Upgrade 2017 300 Limited Realkonceptz Car Audio/Alarms/UConnect/Navigation 0 03-22-2018 05:54 PM
Chrysler 300 / Lancia thema 2012. Trunk button problem Stanislav Müürsepp 2nd Generation Chrysler 300 Discussion 1 05-24-2017 01:53 PM
How to make my 2008 300 Limited 3.5 RWD faster? Strivous Performance General Discussion 3 07-22-2016 03:45 PM
A mock up of the 2018 300 thematrixhasu 2nd Generation Chrysler 300 Discussion 11 06-14-2016 05:33 PM
