New to me 2010 crd tourer. What code reader is everyone using? - Chrysler 300C Forum: 300C & SRT8 Forums
 1Likes
post #1 of 15 (permalink) Old 04-27-2019, 09:55 AM Thread Starter
Points: 203, Level: 1 Points: 203, Level: 1 Points: 203, Level: 1
Activity: 46% Activity: 46% Activity: 46%
Hi just a quick question, my newly acquired crd touring seems a bit slow to fire on cold morning, spin over quite a bit before catching, once started and warm - fine 😀
Just wondered what code reader is cheap n chearfull and will let me see if any heater plug codes are listed etc
Cheers!!
Daz300 is offline
post #2 of 15 (permalink) Old 04-27-2019, 12:23 PM
Elite Contributing Member
Points: 32,929, Level: 1 Points: 32,929, Level: 1 Points: 32,929, Level: 1
I use the TorquePro App on my Android phone, in conjunction with the OBDLinkLX Bluetooth module. This will identify any glowplug and glowplug module faults, to which the CRD seems to be somewhat prone. There are plenty of cheap ELM327 modules around, but you tend to get what you pay for.
devilmaycare is offline
post #3 of 15 (permalink) Old 04-27-2019, 01:14 PM
Points: 1,535, Level: 1 Points: 1,535, Level: 1 Points: 1,535, Level: 1
BiliTheAxe's Avatar
Car: 2007 Chrysler 300 C
Mine isn't a CRD, but I have the same OBDLinkLX that he has. A great little Bluetooth OBD2 adaptor.
It also works incredibly well with some of the PC based code reading software for PC's like AppCar DiagFCA that can even tell you when a speaker in the car has been disconnected.
It will also allow you to make changes to some settings.
Some of the less expensive OBD2 bluetooth adaptors are not very accurate when it comes to showing things like the vehicle's voltage. so do yourself a favor and spend money on a good one.
I've seen cheap ones show 12.5 volts coming in from a running engine with a good alternator and battery, when the voltage was really 14.5. That 2 volts could make you buy a new alternator and battery that you did not need to buy.
https://appcar-diagfca.com/en/?gclid...SAAEgKvPvD_BwE
Please come back and tell us what the solution to your problem was, so that others coming here can learn from it.
Moderator at MoPars unlimited on Facebook.
BiliTheAxe is offline
post #4 of 15 (permalink) Old 04-27-2019, 02:48 PM Thread Starter
Cheers, think I've found torque pro on Google play, £2.99 and the Bluetooth adapter on eBay, about £60 depending, some from China cheaper but long delivery times. Car starts just seems to start better if I count to 5 after glow plug light has gone out.
Ta 😀
Daz300 is offline
post #5 of 15 (permalink) Old 04-29-2019, 06:04 AM
Ta 😀
I was able to buy my OBDLinkLX on Amazon which was offering a £20 cashback at the time - so a good buy. It is fast and reliable and guaranteed to work with TorquePro. I started off with a cheap adaptor fom China, but it was slow and kept reporting comms errors. Starting problems are not uncommon with the CRD, even with good glowplugs. Also, pre-heating doesn't necessarily stop when the warning light extinguishes, but can continue for some time even after the engine has started. Just to play safe, I always wait for all the warning lights to extinguish before cranking.
post #6 of 15 (permalink) Old 04-29-2019, 02:17 PM
Points: 578, Level: 1 Points: 578, Level: 1 Points: 578, Level: 1
Activity: 30% Activity: 30% Activity: 30%
Car: 2015 Chrysler 300C Platinum
Send a message via MSN to 2015Chrysler300c Send a message via Yahoo to 2015Chrysler300c
I've read several positive comments regarding the APPCA-DIAGFCA software. Being new to computer software instead of hand held unit, what else besides a recommended OBD2 adapter, computer and the $49.95 software is needed?
2015Chrysler300c is offline
post #7 of 15 (permalink) Old 04-29-2019, 03:59 PM Thread Starter
Ta 😀
Obdlink ordered, hopefully here this week, have downloaded torque pro 'lite' off Google play as it was free, see how it goes, then might upgrade to paid torquepro .
Daz300 is offline
post #8 of 15 (permalink) Old 04-29-2019, 08:32 PM
BiliTheAxe's Avatar
You need internet access. At least for the first use. Have not tried it without access to the internet since installing it.
You can get codes that are stored but not triggering the check engine light.
You can actually do some diagnostics.
And according to the info on their web page, they will soon be releasing a new version that supposedly will allow people to program keys.
New features:
Still in beta testing
FOB / Key programming for most of 2005-2013* models / some models up to 2018*
PIN Code Reading (needed eg. for keys programming) for most of 2005-2013* models / some models up to 2018*
Advanced Diagnostic Routines, eg. HVAC Actuator Calibration, ABS Initialization, PCM Replace, etc. *
Clearing DTC codes in all modules in one click
Vehicle Configuration Report - it's a report that shows all vehicle configuration settings in one document.
Faster connection process
Software updates once you buy it are free.
https://appcar-diagfca.com/en/how-to-use-it/
The Following User Says Thank You to BiliTheAxe For This Useful Post:
2015Chrysler300c (04-30-2019)
post #9 of 15 (permalink) Old 04-29-2019, 08:55 PM
BiliTheAxe's Avatar
Here is a copy of the report it generated for me.
The report is much easier to follow than my copy and paste of the info.
The report was done about a year ago.
The list of available systems
ABS - Anti Lock Brakes
Part no.: 04779492AJ
Software version: 0002510654
Num of DTCs: 4
No. DTC code DTC status Description
1 C2206 Active Vehicle Configuration Mismatch
2 C121A Stored Steering Angle Sensor Not Initialized
3 C2100 Stored Battery Voltage Low
4 C2101 Stored Battery Voltage High
AHBM - Automatic High Beam
Part no.: 04806261AC
Software version: 04806261AC
Num of DTCs: 0
AMP - Amplifier
Part no.: 05064118AK
Software version: 05064118AK
Num of DTCs: 1
1 B1486 Active Channel 8 Audio Speaker Output Circuit Open
CCN - Instrument Cluster/Cabin Compartment Node
Part no.: 05172058AF
Software version: 04844687AE
Num of DTCs: 0
DDM - Driver Door Module
Part no.: 56038722AP
Software version:
Num of DTCs: 0
EOM - Electronic Overhead
Part no.: 56050243AH
Software version: 56050243AH
Num of DTCs: 0
ESM - Electronic Shifter
Part no.: 04606753AA
Software version: 7604781
Num of DTCs: 0
FCMCGW - Central Gateway
Part no.: 04692140AH
Software version: 04692140AH
Num of DTCs: 0
HFM - Hands Free Module(cell phone)
Part no.: 05064070AI
Software version:
Num of DTCs: 0
HSM - Heated Seat Module
Part no.: 04602670AD
Software version:
Num of DTCs: 0
HVAC - Heat, Ventilation and A/C
Part no.: 55111030AH
Software version: 55111030AJ
Num of DTCs: 0
LRSM - Light Rain Sensor module
Part no.: 56050078AN
Software version: 56050078AN
Num of DTCs: 0
MSMD - Memory Seat
Part no.: 04602799AD
Software version: 04602799AD
Num of DTCs: 1
1 B210D Stored Battery Voltage Low
ORC - Occupant Restraint
Part no.: 68001371AB
Software version: 68001371AB
Num of DTCs: 0
PCM - Powertrain Control Module
Part no.: 05187842AA
Software version: 05187842AA
Num of DTCs: 1
1 P0138 Stored O2 Sensor 1/2 Circuit High
PDM - Passenger Door Module
Software version:
Num of DTCs: 0
RADIO - Radio
Part no.: 05064184AF
Software version:
Num of DTCs: 2
1 B1422 Stored Audio DVD Read Error / Inoperable Disc
2 U0208 Stored Lost Communication With Heated Seat Control Module
SCM - Steering Column
Part no.: 0UZ66XXXAO
Software version:
Num of DTCs: 0
SDAR - Satellite Radio
Part no.: 05064075AE
Software version: 05064075AE
Num of DTCs: 1
1 U0208 Stored Lost Communication With Heated Seat Control Module
SUNR - Sunroof
Part no.: 56010699AL
Software version: DCX : 320
Num of DTCs: 0
TCM - Transmission Control Module
Part no.: 05150186AH
Software version: 05150186AH
Num of DTCs: 0
WCM - Wireless Control
Part no.: 05026182AF
Software version: 05026182AF
Num of DTCs: 5
1 B1A28 Stored ECM Mismatch with SKIM
2 B1A35 Stored Unidentified Key Communication Error
3 C0077 Stored Low Tire Pressure
4 C1503 Stored Tire Pressure Sensor 3 Internal
5 C150A Stored Left Front Tire Pressure Trigger Module - Voltage High
The Following 2 Users Say Thank You to BiliTheAxe For This Useful Post:
2015Chrysler300c (04-30-2019), devilmaycare (05-01-2019)
post #10 of 15 (permalink) Old 04-30-2019, 12:01 PM Thread Starter
Got adapter today, tried the torque lite app, connected to each ok, checked for codes, no stored, no historic, could deliver data for boost etc, so it looking like could be car battery as it was showing 11.5v at ign on and slowly dropping and around 10v when cranking. BUT car is not being used at moment as waiting for DVLA to extract a digit from their bum and get the v5 to me so I can tax it, need v5 as currently on disabled rate and changing bro normal for me.
Thank you all for yet help, much appreciated :-)
Daz300 is offline
The Following 2 Users Say Thank You to Daz300 For This Useful Post:
Auto dimming mirror a_hemi_hunter Appearance General Discussion 7 12-26-2018 01:28 AM
New 2010 300C CRD SRT owner. Need some help! Sparhawk12345 New Member Introductions 1 01-07-2017 01:15 PM
