Car cuts off - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 5 (permalink) Old 04-11-2019, 10:27 AM Thread Starter
Points: 98, Level: 1 Points: 98, Level: 1 Points: 98, Level: 1
Activity: 22% Activity: 22% Activity: 22%
I'm having an issue with my 300C, the car is cutting off and this has recently started. Two codes came up, one U0100 and two P0700, can someone assist. It starts back but may work for a little while and cuts off again
sello2119 is offline
post #2 of 5 (permalink) Old 04-11-2019, 07:29 PM
Administrator
Points: 104,857, Level: 1 Points: 104,857, Level: 1 Points: 104,857, Level: 1
MADDOG's Avatar
U0100 means the car and PCM have lost communication.
The P0700 code means the transmission control module has lost communication with the PCM.
Check the main harness connection to your computer. It may be loose, dirty, have some condensation in it or it may be corroded.
Also, check your main power connections and ground at the battery and the underhood power center.
If the connections are in good condition it may very well be a bad PCM.
Michael
MADDOG is online now
post #3 of 5 (permalink) Old 04-14-2019, 12:13 PM Thread Starter
Hi maddog letting you know that I discovered what is the problem with the car cutting off. I did what you advised me to do, but that wasn't showing any signs
Apparently the PCM started to malfunction causing the car to cut off on the run. Temporarily replaced it and problem solved. Thanks for the support
post #4 of 5 (permalink) Old 04-14-2019, 12:51 PM
Administrator
MADDOG's Avatar
Thanks for the update. I suspected as much but it's always a good idea to check the simple, and cheaper, items first.
post #5 of 5 (permalink) Old 06-02-2019, 08:43 AM Thread Starter
Engine oil
Hi guys have a question.....if I am unable to get 5w20 engine oil, is it safe to use 0w20 or 0w30 engine oil?
2006 300C car shuts off (no Power) while driving Johnnys440Charger General Discussion on Issues / Trouble Shooting 0 11-27-2018 01:13 PM
Car cuts off Cjbean05 General Discussion on Issues / Trouble Shooting 1 09-13-2017 10:43 AM
Headlights stay on when in A after car is off BLUE_DEMON General Discussion on Issues / Trouble Shooting 2 07-12-2017 12:27 PM
Cannot turn car off GMR General Discussion on Issues / Trouble Shooting 2 08-19-2016 07:25 AM
FOB Not Being Released When Switching Off Car jchchrysler CRD Electrics / Electronics / Lighting 15 02-02-2016 02:40 PM
