Starter - Chrysler 300C Forum: 300C & SRT8 Forums
 1Likes
post #1 of 13 (permalink) Old 04-18-2019, 08:37 PM Thread Starter
Points: 42, Level: 1 Points: 42, Level: 1 Points: 42, Level: 1
Activity: 50% Activity: 50% Activity: 50%
Starter
2005 300 c 5.7 Rear wheel drive.
Car has sat for 8 months replaced batter car wonít start just one click not turning over. I put car in Neutral put socket on engine pulley and move pistons a bit so I know engine engine isnít seized.
So I am thinking dead starter. Here is my question everything I search in google comes up very minimal information on the starter repair I have read itís on drivers side underneath between trans and engine. I dot see it. But on passenger side I do see this which I believe is the starter. Can anyone confirm it could be on passenger side and is this pic the starter. I know it sounds dumb it just has me really baffled
Sent from my iPhone using Tapatalk
kjayz is offline
post #2 of 13 (permalink) Old 04-18-2019, 08:46 PM
Administrator
Points: 103,915, Level: 1 Points: 103,915, Level: 1 Points: 103,915, Level: 1
MADDOG's Avatar
So one question...did you load test the battery?
Michael
MADDOG is offline
post #3 of 13 (permalink) Old 04-18-2019, 09:48 PM Thread Starter
Yes sir appreciate that information though.
Iím just perplexed that it seems some starters are on the left some on the right and it appears awd on the right rwd on left just want to confirm And if in the pic that is the starter
kjayz is offline
post #4 of 13 (permalink) Old 04-19-2019, 03:14 PM
Points: 25,240, Level: 1 Points: 25,240, Level: 1 Points: 25,240, Level: 1
Activity: 43% Activity: 43% Activity: 43%
Hosehead's Avatar
Car: 2006 Chrysler 300 SRT8
Yes, that is the starter.
It could be a sticky solenoid after sitting for that length of time.
I would try tapping the starter solenoid with a soft hammer while someone engages the key to start position.
Of course a load tested battery is critical.
Hosehead is offline
post #5 of 13 (permalink) Old 04-19-2019, 04:13 PM Thread Starter
Thanks I took it out of the car no problem I will bench test it see how it is. I have brand new battery in the car and tested. So will see what it does on the bench.
kjayz is offline
post #6 of 13 (permalink) Old 04-19-2019, 04:14 PM Thread Starter
kjayz is offline
post #7 of 13 (permalink) Old 04-19-2019, 06:23 PM
Points: 85,741, Level: 1 Points: 85,741, Level: 1 Points: 85,741, Level: 1
So how'd the bench test go?
DESIREE is offline
post #8 of 13 (permalink) Old 04-20-2019, 02:37 PM Thread Starter
Works perfectly so I have no idea what the deal is. Friend suggested the starter may just be to weak good on a bench but not enough to crank engine. I just donít know if itís security issue with key fob or what at this point. Iím going to clean up the connections put it back in car And run a lead from solenoid to 12 volt see if she goes
kjayz is offline
post #9 of 13 (permalink) Old 04-20-2019, 06:49 PM
Check fuses 10 (5A) and 20 (20A), and the Starter relay in the Integrated Power Module (aka the engine compartment fuse box). Simply removing them for inspection and reinserting each should cleanup any corrosion or loose fitting issues that may be causing them not to function properly.
DESIREE is offline
The Following User Says Thank You to DESIREE For This Useful Post:
kjayz (04-20-2019)
post #10 of 13 (permalink) Old 04-20-2019, 08:50 PM Thread Starter
Thanks for that Iíll try
kjayz is offline
F/S: Flashlogic remote starter chrysler 2005 and up frank6060 Parts Buy/Sell Forum 0 12-09-2017 08:52 AM
Handle any emergency with Compact Jump Starter from Torxe! CARiD CARiD.com 0 05-22-2017 03:53 AM
Starter OK but delayed cranking when turning key FOB skylane General Discussion on Issues / Trouble Shooting 2 10-03-2016 08:57 AM
2013 V6 AWD - Cant get my starter off stone4779 2nd Generation Chrysler 300 Discussion 7 07-07-2016 12:46 PM
Long tube header hitting starter motor V8 WEV 1st Gen SRT8-Specific Performance & Engine/Intake/Exhaust Mods 4 08-03-2015 12:37 PM
