R/T Axles in an 06 srt8 - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 11 (permalink) Old 11-07-2013, 11:13 AM Thread Starter
Points: 33,583, Level: 1 Points: 33,583, Level: 1 Points: 33,583, Level: 1
MY SRT8 HEMI's Avatar
Getting a set of 09 R/T axles need a set of hubs 31 spline i hear good things about the set-up VS our stock srt8 axles anyone do this swap...how hard was it?,,,Anyone know a good place to buy the hubs from??? thanks.
2006 BB 300C SRT8.,LMI cai,BT oil catch, bilstein shocks all around, dc sport top carbon steel strut tower bar, challanger motor mounts., alpine touch screen,Blue tops,Custom exhaust suitcase removed...magnaflow resonators 4 inch tips,91 CAI Tune,NO plate and nitrous outlet solenoids,Running nano too.
Gone ..2006 Dodge Magnum SRT-8
Other toys:
06 Magnum SRT,03 Excursion
98 GMC suburban,04 Trailblazer
Wifes toys 91 Camaro z28 350 tpi supercharged
89 Camaro I-roc 350 tpi some mods
MY SRT8 HEMI is offline
post #2 of 11 (permalink) Old 11-07-2013, 12:10 PM
Points: 58,706, Level: 1 Points: 58,706, Level: 1 Points: 58,706, Level: 1
Sodak's Avatar
Car: 2006 Chrysler 300c SRT8
Speedlogic has this setup and they can tell you what you'll need. It's on my list as well..... somewhere..
See My Garage
https://www.300cforums.com/forums/gar...ehicle_id=1129
SRT A Factory Hotrod
Sodak is offline
post #3 of 11 (permalink) Old 11-07-2013, 12:19 PM Thread Starter
TO be honest i have a forum memeber giving me a set of RT axles he went to a Getrag...i just needs the hubs...lol thats why i was asking if anyone knew were i can get them cheap...lol....
So will they hold up with DR's and nitrous...lol
post #4 of 11 (permalink) Old 11-07-2013, 01:21 PM
Sodak's Avatar
You could try Cleavland pick a part.
Sodak is offline
post #5 of 11 (permalink) Old 11-07-2013, 01:40 PM
Points: 89,703, Level: 1 Points: 89,703, Level: 1 Points: 89,703, Level: 1
silver06hemic's Avatar
Ok what did I miss here? R/T axles stronger than SRT? I know that the 09 chally and charger SRT axles and diff are tougher and LSD... But what gives on the R/T ones?
FRI'd Sidewinder, Novi 1200 S/C @ 7.5psi, Custom TR1235 A2A Intercooler, Tial BOV, Ported SRT Headers & Gutted Mid's, EGR, MDS & 02 Delete, Custom Catback w/Blastin Bobs SRT Pipes 4" tips, 170 Tstat, Big Bully Catchcan, 3.06 diff, 2800 stall, MTCM, Tranzformer, SRT Rad, SRT P/S Cooler, 5/15% Tint, SRT 20's, SRT Spoiler & Bumpers, Custom Stainless Grill, SE Coilovers.
AMP'd, FRI'd and Blown... 476rwhp/507rwtq @ 7.5psi
[email protected] 7.5psi/DR's
silver06hemic is offline
post #6 of 11 (permalink) Old 11-07-2013, 02:22 PM Thread Starter
This is what I was told...over LX forums...
yea, for stock SRT dif of that year; the 09+ RT axles are a great upgrade.
you need axles and hubs. the hub side has a 31 spline instead of the small 28 spline ends we always broke.
I have these on my 06 300 SRT and put down 680 to the wheels, no problems.
So these axles are a direct swap for the stock SRT 3.06..
Pop out the stock axles, change the hubs, install the new axles and go?
Pre-09 cars have the following:
- SRT's have 215mm ring gear; RT's have 210mm ring gear
- SRT's have 3.06 gear ratio; RT's have 2.82 gear ratio
- open differential (non-LSD)
- weaker axles
- 28 spline hubs
- SRT's have 4 bolt driveshafts; RT's have 3 bolt driveshafts
The two things you want to upgrade are:
1. Weak Axles
- the post-09 axles are stronger (I'm not aware of one breaking)
- the post-09 axles are a drop in replacement but need the post-09 31 spline hubs
- the post-09 axles will work with the pre-09 open differential
2. Open Differential
- the post-09 differential is an LSD Getrag
- the post-09 differential has 226mm ring gear which should be a little stronger than 215 or 210
- the post-09 differential will work with the pre-09 axles
- pre-09 SRT's need to change to a 3 bolt driveshaft; pre-09 RT's can use the existing driveshaft
'09 Auto R/T Challenger axles have the beefed up hub end with the 215mm differential end for the 3.06 '05-'08 SRT's.
6-spd '09 Challenger R/T's got the Getrag unit with the full 226 axles.
The rest of your info looks good.
to me seems like a good way to keep the axles from breaking and pretty reasonable price...
The Following 3 Users Say Thank You to MY SRT8 HEMI For This Useful Post:
Copperpearl2011 (04-19-2015), Kaiser Bill (11-07-2013), peter2772000 (11-07-2013)
post #7 of 11 (permalink) Old 11-07-2013, 03:16 PM
Absolutely never heard of this before! Learn something new everyday! Good find!
The Following User Says Thank You to silver06hemic For This Useful Post:
MY SRT8 HEMI (11-07-2013)
post #8 of 11 (permalink) Old 11-07-2013, 03:19 PM Thread Starter
Yeah im going to give it a shot see how they work out....
post #9 of 11 (permalink) Old 11-23-2013, 05:37 PM
Major Contributing Member
Points: 7,543, Level: 1 Points: 7,543, Level: 1 Points: 7,543, Level: 1
srt8-in-largo's Avatar
Car: 2006 Chrysler 300 SRT8
I just popped on a Getrag setup. Erik at BFNY will sell you whatever you need, including hubs. Fair prices.
In a nutshell:
2009+ RT's (Chally, Charger, 300)
- rear diff changed to the 215mm (same one used in the pre-09 SRT's)
- the diff flange remains as a 4-bolt
- stronger axles; 28 spline at the diff, 31 spline at the hub
- these will bolt into pre-09 SRT's provided you get the 31 spline hubs
2009+ SRT's (Chally 6-speed, Charger, 300)
- rear diff changed to the 226mm Getrag
- the diff flange changed to a 3-bolt
- same stronger axles as the RT's except with 31 spline at the diff, 31 spline at the hub
Here the thread that'll teach you everything you nee to know:
Any truth to this rumor? 09 half shafts...
- weaker axles
- 28 spline hubs
1. Weak Axles
- the post-09 axles are stronger (I'm not aware of one breaking) These have been breaking.
- the post-09 axles are a drop in replacement but need the post-09 31 spline hubs Only true for the post-09 RT axles; post-09 SRT axles are 31 spline on both ends and won't boltin unless you get the Getrag too
- the post-09 axles will work with the pre-09 open differential This is because it's the same 215mm diff
- the post-09 differential is an LSD Getrag Only true for SRT and 6-speed Chally's
- the post-09 differential has 226mm ring gear which should be a little stronger than 215 or 210 The Getrag is 226mm; RT uses the old 215mm diff
- the post-09 differential will work with the pre-09 axles Only true for RT's
I posted the above bold on LXF... thanks for the props . Needs a couple of clarifications, in red.
If you're running 680 rwhp on the RT axles, you're on borrowed time. If you hook just right that power will break them.
George
2006 300 SRT8, Brilliant Black
Kenne Bell 2.8LC, AMP installed, Johan tuned
srt8-in-largo is offline
post #10 of 11 (permalink) Old 10-28-2018, 08:19 AM
Points: 2, Level: 1 Points: 2, Level: 1 Points: 2, Level: 1
300c hemi grandpa's Avatar
I have a 2008 300c 5.7l. So will this axle swap work on it. I am building a Grandpa sleeper and need to beef the rearend up. Any advice would e greatly appreciated. Thank you
300c hemi grandpa is offline
SOLD: Feelerrrr srt8 3.06 rear diff and axles dsahota Parts Buy/Sell Forum 2 12-24-2011 02:19 PM
EXPIRED: F/S: 6.1 Axles/Hubs tdola Parts Buy/Sell Forum 0 05-16-2009 02:02 PM
Frozen axles Meister Performance General Discussion 33 07-03-2007 07:05 AM
Busted Axles Rev.Hammer Performance General Discussion 0 02-15-2007 07:39 PM
covini c6w..3 axles! phillips2024 Other Vehicle Makes & Models Discussion 6 12-09-2006 03:08 PM
