ABS implausibility Code U140E - Page 4 - Chrysler 300C Forum: 300C & SRT8 Forums
 1Likes
post #31 of 44 (permalink) Old 11-28-2017, 08:11 AM
Elite Contributing Member
Points: 75,161, Level: 1 Points: 75,161, Level: 1 Points: 75,161, Level: 1
UK CHRYSLER 300C's Avatar
I got it now after a bit of a mix up but my Elm doesn't work with it so I've ordered one off Ed's link
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
UK CHRYSLER 300C is offline
post #32 of 44 (permalink) Old 11-28-2017, 08:20 AM
Points: 1,339, Level: 1 Points: 1,339, Level: 1 Points: 1,339, Level: 1
Ed Harrison's Avatar
Car: 2006 CHRYSLER 300 CRD
I am not the best with patience or technology - my advice take your time, bluetooth can take 30 / 60 secs to connect / check it is paired in bluetooth settings, it drove me mad for days but they talked me throught it very well.
My tpms shows individual pressures so I thought I had the premium and clicked disable - No luck, so I selected basic tpms and disabled and it worked.
Ed Harrison
Ed Harrison is offline
post #33 of 44 (permalink) Old 11-28-2017, 08:31 AM
It's ok Ed I use technology all the time.....lol... Oh and just to let you all know you don't need TPMS for cars from 2012 for the MOT, the fail criteria is if the TPMS shows a fault,so if you turn them off no fault light at all so not a fail,same with airbag light too,both sets of lights do not need to come on with ignition or start-up but if they come on and stay on then it's a fail. ABS light HAS to come on then go off the others don't
post #34 of 44 (permalink) Old 11-28-2017, 09:09 AM Thread Starter
Points: 7,090, Level: 1 Points: 7,090, Level: 1 Points: 7,090, Level: 1
Can I ask one of you guys a big favour?
Could you look at your ABS using the software and go into the live data.
You can select PIDS...
Could you tell me what reading you get for ECU voltage to ABS pump feed.
Mine is reading OUT OF RANGE.
Dreamcatcher300 is offline
post #35 of 44 (permalink) Old 11-28-2017, 09:48 AM
Out of Range means the pumps faulty
post #36 of 44 (permalink) Old 11-28-2017, 09:57 AM Thread Starter
The pump is actuating on request and all the valves are reporting as they should. I think that dead battery I had has messed up the CAN C.
Might just have to bite bullet and get a new one.
post #37 of 44 (permalink) Old 12-01-2017, 08:56 AM
Finally got the [email protected] thing to work at last.....no more tyre warnings or chimes,not a bad bit of kit for the money
Ed Harrison likes this.
post #38 of 44 (permalink) Old 12-01-2017, 08:58 AM
I had a bad time with impatiently pressing buttons but worth the wait - was thinking of playing with the DRL settings next
post #39 of 44 (permalink) Old 12-01-2017, 11:33 AM Thread Starter
Well it has to be said....Ed thanks for putting us onto this product I've told a fair few 300C owners now and they're all considering buying it.
post #40 of 44 (permalink) Old 07-16-2018, 06:14 AM Thread Starter
Well after almost 1 year of investigation I've finally found the resolve for U140E.
The CANBUS issue I initially reported in this post was in fact a totally separate issue.
The cause of U140E was a dead battery.
I'll explain both and give you the resolve.
It turns out that my CANBUS fault was a short to ground on the dynamic sensor power wire and it caused the CANBUS to go haywire. The wire was chaffed to chassis and is now fixed.
The only code left after the repair was U140E caused by the dead battery. Apparently the PCM did not like the voltage spike on battery recharge and now there's a mismatch in VIN from the ABS module. I'm told the only way to repair this is to reflash the system using WITECH pass thru with TECHAUORITY WEB SITE or you can use your own J2534 and buy a 1 day subscription from TECHAUORITY and reflash it yourself.
I'm opting for ACD to fix it but after after speaking to several techs there's only 2 ways to clear this code... way 1 is to drive the car and see if it resets itself and if it doesn't then way 2 is a reflash.
Pain in the backside but I hope this will help someone else and I apologise if my previous information mislead anyone.
Auto dimming mirror a_hemi_hunter Appearance General Discussion 7 12-26-2018 01:28 AM
U1408 code: abs & tc lights on GritsNGravy 2nd Generation Chrysler 300 Discussion 0 05-15-2017 04:17 PM
ABS Unit's electric connector PetriA UK & Europe Regional Forum 1 08-03-2016 12:47 AM
Code U0104 - dubious about Trinity translation Kaiser Bill General Discussion on Issues / Trouble Shooting 4 04-15-2016 07:30 AM
Help please. I'll pay? Abs fault mohsinmalikuk CRD Electrics / Electronics / Lighting 7 09-16-2015 01:34 PM
