Anti-roll bar bush change - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 6 (permalink) Old 12-16-2018, 05:42 AM Thread Starter
Points: 2,080, Level: 1 Points: 2,080, Level: 1 Points: 2,080, Level: 1
Car: 2007 Chrysler 300C
Hi,
I've read a number of articles about changing these and am still not sure if it is necessary to reduce the load before removing the bushes.
I think my options are:
1) Try and replace with the car on the ground, although I think there may not be enough space to get to the bushes
2) Put the car on ramps to give me good access
3) Jack up one side, place on an axle stand, do one bush, then lower and jack up the other side to do the other bush
4) Jack up and both sides and support both side on axle stands
So my question is, which is the easiest method and do I need to reduce the load on the ARB?
2 more questions please:
1) It looks like MOOG bushes are better that the originals, are these best ordered from the 300C Custom Shop?
2) The heat shields are missing. How important are these?
Thanks.
AB77 is offline
post #2 of 6 (permalink) Old 12-16-2018, 07:14 AM
Points: 504, Level: 1 Points: 504, Level: 1 Points: 504, Level: 1
Car: 2006 Chrysler 300c Srt8
I'll assume these are for the front. I did mine with both sides up on jack stands. I would find or make new heat shields to keep the new ones intact for as long as possible.
Sent from my SM-G950U using Tapatalk
2006 300c Srt8: HHP Stage 2R Cam, Thitek Ported Heads, Kooks Longtubes, Ported Intake Manifold, 87mm TB, LMI True CAI, 3.91 Getrag, Hemituner 6,800rpm TCM, 8 Piston AMG Calipers, 15.4" front rotors, Widened OEM wheels wrapped in Michelin PS4, 32/22mm F/R sway bars, Bilstein shocks, F/R strut braces
bm_srt is offline
The Following User Says Thank You to bm_srt For This Useful Post:
AB77 (12-16-2018)
post #3 of 6 (permalink) Old 12-16-2018, 07:57 AM Thread Starter
Thanks, yes, I'm doing the front bushes.
Did you use the blue MOOG bushes or just the standard one?
AB77 is offline
post #4 of 6 (permalink) Old 12-16-2018, 09:41 AM
DGO
Major Contributing Member
Points: 12,803, Level: 1 Points: 12,803, Level: 1 Points: 12,803, Level: 1
Car: 2013 & 2014 Chrysler 300c CRD & 300 AWD
Raise the car (I'm sure I don't need to say - with all the usual precautions), undo the drop links and then you can get to the bar. As above be careful with the heatshields.
As for the bushes to use I have just bought the latest MOOG ones which have an internal lining that's supposed to stop squeaks: MOOG which I bought from Rockauto (make sure you get the right size for your Sway Bar as they come in 3 sizes.
I'm going to install them when the weather is better
DGO is offline
post #5 of 6 (permalink) Old 12-16-2018, 06:32 PM
I installed a thicker sway bar and used the ones that were provided with the bar.
bm_srt is offline
post #6 of 6 (permalink) Old 12-16-2018, 06:52 PM
Points: 1,609, Level: 1 Points: 1,609, Level: 1 Points: 1,609, Level: 1
Activity: 58% Activity: 58% Activity: 58%
BiliTheAxe's Avatar
Car: 2007 Chrysler 300 C
I've done them on other cars on the ground, and with the wheels off of the ground.
Just doing the bushings on the frame for the swaybar, are not hard to do, one at a time.
It is infinitely easier to do the job with both wheels off of the ground, because there is no tension on the sway bar, so it requires almost zero effort to replace them.
If you remove the endlinks to replace the the swaybar with a heavier duty one.
On ramps, it sometimes requires using a floor jack to force the swaybar upwards to get it to where you can attach the endlink to one side.
Please come back and tell us what the solution to your problem was, so that others coming here can learn from it.
Moderator at MoPars unlimited on Facebook.
BiliTheAxe is offline
The Following User Says Thank You to BiliTheAxe For This Useful Post:
AB77 (12-17-2018)
2015 V6 Oil Change question 2k15on22s 2nd Generation Chrysler 300 Discussion 13 10-25-2016 01:17 PM
