Help! My car is sick! - Page 3 - Chrysler 300C Forum: 300C & SRT8 Forums
 2Likes
post #21 of 38 (permalink) Old 01-10-2019, 02:22 AM Thread Starter
Points: 16,719, Level: 1 Points: 16,719, Level: 1 Points: 16,719, Level: 1
Activity: 44% Activity: 44% Activity: 44%
feichter's Avatar
Car: 2007 Chrysler 300C CRD
UPDATE:
Drove it this morning without any problems, except for the initial ping to tell me that a glowplug is not working. Done the 'easter egg' thing and it reports 'LastChime: glowplug'. Have booked it into the local garage to get it changed tomorrow morning.
Another question:
Under the 'LastChime' there are a further three lines. What do they mean?
VTA: none
Wake: FtDrvDr
VMM 543
feichter is offline
post #22 of 38 (permalink) Old 01-10-2019, 03:27 AM
DGO
Major Contributing Member
Points: 12,801, Level: 1 Points: 12,801, Level: 1 Points: 12,801, Level: 1
Car: 2013 & 2014 Chrysler 300c CRD & 300 AWD
The last ping should be glowplugs. I've had one not working for a couple of years, haven't had it changed yet
DGO is online now
post #23 of 38 (permalink) Old 01-10-2019, 03:43 AM
Points: 13,919, Level: 1 Points: 13,919, Level: 1 Points: 13,919, Level: 1
Car: 2010 Chrysler 300C
Originally Posted by feichter View Post
UPDATE:
Another question:
VTA: none
Wake: FtDrvDr
VMM 543
VTA - is "Vehicle Theft Alarm" and lists the last trigger that set the alarm off.
Wake - is something to do with what last woke the "system" up - in your case, Front Driver's Door.
VMM - I think is a software version.
If you want to know what the alarm sounds like, and you have a saloon, put the rear seats down, lock the car, open the boot from the keyfob and stick something into the boot and into the interior area - it'll trigger the ultrasonic movement detectors.
For the avoidance of doubt, your faulty glowplug 6 is the rear-most one (closest to the passenger compartment) on the passenger side. I think there was a diagram somewhere in the service manual that shows the cylinder numbers wrong!
As for dealers, in Kent I've used Lipscomb in Maidstone for a couple of recalls and a starter motor wiring repair - all good. But no knowledge further East I'm afraid.
talldave is offline
The Following User Says Thank You to talldave For This Useful Post:
feichter (01-10-2019)
post #24 of 38 (permalink) Old 01-10-2019, 04:19 AM Thread Starter
feichter's Avatar
Thank you so much, talldave!
feichter is offline
post #25 of 38 (permalink) Old 01-13-2019, 01:49 PM Thread Starter
feichter's Avatar
Well, got the glowplug done, but the lights (lighting bolt, eps and skid light) are back on.
So it's going back in on Tuesday.
Sent from my Redmi 4 using Tapatalk
feichter is offline
post #26 of 38 (permalink) Old 01-15-2019, 10:32 AM Thread Starter
feichter's Avatar
Ok. Got the car back from a local garage, but not fixed. The codes are too complex and they can't get involved. So, back to square one.
They gave me a print out of the codes:
PCM - Powertrain control module
U0101 - Lost communication with TCM
ABS - Anti Lock Brakes
MIC/CCN - Mechanical Instrument cluster
B1808 - Passenger door lock/unlock switch circuit stuck lock
CGW - Central Gateway
What now??
feichter is offline
post #27 of 38 (permalink) Old 01-15-2019, 12:32 PM
Points: 85,741, Level: 1 Points: 85,741, Level: 1 Points: 85,741, Level: 1
What now??
From the service manual:
'U0101-LOST COMMUNICATION WITH TCM
When Monitored:
With the ignition on
Battery voltage between 10 and 16 volts
IOD fuse installed
FCM is configured correctly
Set Condition:
Bus messages not received from the TCM for approximately 500ms.
Possible Causes:
CAN B OR CAN C BUS CIRCUITS OPEN OR SHORTED
DTCS RELATED TO BATTERY VOLTAGE, IGNITION, OR VIN MESSAGES
FCM NOT CONFIGURED CORRECTLY
TCM
TCM POWER AND GROUND
MODULE THAT SET THIS DTC'
So, how's the battery's condition?
DESIREE is offline
post #28 of 38 (permalink) Old 01-15-2019, 04:31 PM
You can monitor the battery voltage from the EVIC hidden menu.
talldave is offline
post #29 of 38 (permalink) Old 01-15-2019, 06:37 PM
Don't start the engine, just turn the key to the on position so as to get a measurement without the alternator charging, get into the EVIC screen that shows voltage, note the voltage, then crank the engine and note the voltage while cranking and immediately after the engine starts.
DESIREE is offline
post #30 of 38 (permalink) Old 01-15-2019, 08:59 PM Thread Starter
feichter's Avatar
Will do....
feichter is offline
Car still shaking Dakur 2nd Generation Chrysler 300 Discussion 18 06-13-2017 10:24 AM
newbie, great car! not so good dealer experience Adder72 2nd Gen SRT- General Discussion 8 11-02-2016 02:58 AM
Advice on selling car svisek General Discussion 13 09-19-2016 09:57 AM
So, I'm bringing my new-to-me car home and... Jim777 Off-Topic Discussion 11 11-21-2015 11:43 AM
Car wanders to the right Garrett Craig General Discussion on Issues / Trouble Shooting 6 08-26-2015 07:55 PM
