Air Suspension Questions - Page 34 - Chrysler 300C Forum: 300C & SRT8 Forums
post #331 of 338 (permalink) Old 10-28-2014, 09:11 AM
Points: 22,903, Level: 1 Points: 22,903, Level: 1 Points: 22,903, Level: 1
Crunkz1's Avatar
Car: 2013 Chrysler 300C
I jacked the car up, took the wheel off, jacked the whole assembly up so it'd push the strut and everything up (not sure if it helps but.. i tried) and then i checked out that whole part, I took off the nut, and it looked like there is a metal sleeve thats sitting down in there as well, which I'm pretty sure was also stopping me from wrenching that nut down any further. I even tried to torque it down so hard, that it stripped the top of that strut rod part out.. I cant get a wrench to fit it anymore, i'll have to use vice grips next time I attempt it. So am I supposed to pull that metal sleeve off? Cause it's kind of down in where the rubber is, Hard to get to.
And thanks bigal!
@Dumped_300C
Crunkz1 is offline
post #332 of 338 (permalink) Old 10-28-2014, 10:07 AM Thread Starter
Points: 24,075, Level: 1 Points: 24,075, Level: 1 Points: 24,075, Level: 1
Actually, you need the washer under the bushing. to keep the shaft from pushing though the bushing.
https://www.universalairsuspension.c...ort/LXInst.pdf Page 8 shows drawing
The Following User Says Thank You to UniversalAirSuspension For This Useful Post:
Crunkz1 (10-28-2014)
post #333 of 338 (permalink) Old 10-28-2014, 10:54 AM
Crunkz1's Avatar
Thats how I have it though, The picture shows the upper bushing goes on before the washer. So you're saying put it under the bushing? That center sleeve is what looked like is stopping me from wrenching that nut down any further.
Crunkz1 is offline
post #334 of 338 (permalink) Old 10-28-2014, 10:55 AM Thread Starter
there is two washers, one on top and one on the bottom.
post #335 of 338 (permalink) Old 10-28-2014, 11:01 AM
Crunkz1's Avatar
Alright, I'll have to find a good day that I can take the struts back out, I'll double check all that assembly up there and see whats going on.. I printed out that page so I can check with it. So that should be my issue then right? for the slight rattle noises I hear? Because I know I have the washers on for both top and bottom, But I can't remember Exactly if the bottom washer went on before the bushing, I think that's how I did it, but I can't remember few months back.. I'll double check it soon as I can.. It's not going to break anything will it? I mean, its my only daily driver I have..
Crunkz1 is offline
post #336 of 338 (permalink) Old 10-28-2014, 11:33 AM Thread Starter
I would say to grab a washer that fits over the threaded section on the shock shaft (largest od upto about 2" possible), then jack the car up, pull the 3 nuts off the top, top shock nut reach through the hole in the tower to take the 2 bag bolts off and remove the entire upper strut mount. Put the washer on the shaft, then reassemble.
I would suggest fix sooner then later, your going to grind out the inside of the upper mount with the shaft wiggling around in there.
post #337 of 338 (permalink) Old 10-28-2014, 11:38 AM
Crunkz1's Avatar
Alright, I'll see if I can't get to it a night this week or Saturday.. National Guard got us running busy with 3 weekends of stuff in a row.. haha and on top of that - family matters as well. If the rain holds off, I'll see if I can't pull it tonight. Thanks for everything! As soon as I get to it I'll post an update and see whats up.
Crunkz1 is offline
post #338 of 338 (permalink) Old 11-24-2014, 09:49 AM
Crunkz1's Avatar
Got the chance to pull the struts over the weekend on Saturday. It was exactly in the area where you have mentioned.
I had both washer, I was however missing the Lower Bushing.
Is this something that's a stock part? or was that supposed to come with the air kit?
I've talked to my buddy (who helped me do the bags) And we have no recollection of a lower bushing (at least we don't remember.. lol)
But the shop guy and I had fabricated a bushing from another car to fit for a fix, and its smooooooooth... this thing rides better than the day i bought her. Love riding on a pillow of air!
Thanks!
Crunkz1 is offline
EXPIRED: F/S: air suspension SYS300C Parts Buy/Sell Forum 3 12-09-2008 12:42 AM
300C transmission shifting, and suspension questions.. TheFleshRocket General Discussion 12 12-13-2007 09:10 PM
300C AWD Owner - Suspension Questions irieman Suspension/Handling Modifications 5 10-09-2007 06:58 PM
questions about suspension kw, eibach, h&r, air suspension golden300 Appearance General Discussion 1 08-12-2007 07:51 PM
New Air Ride Installed- Universal Air Suspension mvpatriot Suspension/Handling Modifications 18 03-25-2006 02:30 PM
