1 - 2 of 2 Posts
I have a Touring Model (I have the capability for group II) I have all 4 front door and rear deck speakers minus the 8 inch. I also have the 3 front dash speakers but only my OEM rears worked cause my fronts were shot and the magnet fell off of one speaker. I assumed that there are no speakers in the front dash since they dont work either. I replaced the rear 6x9's with momo/polks ones but I couldn't install the front speakers. I guess they are a very shallow mounted 8inch speaker in the doors. According to my installer I need a bracket for the 6x9's where can I get this or does anyone have a template for it. Also any suggestions on adding a 8inch aftermarket sub to the rear deck or would it be even worth it? Thanks
I take it you were going to install 6x9 in front and found a round
speaker instead...
I think the bracket is available at the dealer, but you can also
check some of the vendors in this forum.
another alternative is to make your own baffle and use a round
speaker. Since you got polk momos, I happen to know for
a fact that they are very good, since I'm using the 6.5 components
upfront and 6x9 in back.....
1 - 2 of 2 Posts
