Gauge shows empty but the EVIC seems to be reading fuel related info OK which leads me to believe the tank unit is OK. The car has 110,000 km on it.
Is this a common problem and am I looking at a cluster replacement or is there a braindead easy to find/fix wiggle a wire solution? :fingersx:
Kevin
It reads distance to empty and fuel mileage plus it show the left and right side tank readings. When you fill it up the EVIC returns to full tank readings as far as DTE etc but the gauge itself is mostly dead. It will occasionally register but only briefly then it goes to E and stays there.
Kevin
It does sound like a gauge problem and it may be simply the connection to the back of the unit vs. the sending unit in the tank or the gauge itself.
